3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Nyan Cat Rocket
Nyan Cat Rocket
  • last photo ←
K9 has been bothering me for someone to hang out with while I'm in class, but my budget for this month is on the brink
of  falling into the Red so I needed to come up with a buddy for k9 on the cheap hence this instrubtible was born. I started thinking about what should I make when I heard it comming from my room mates room "it" being the Nyan Cat theme. It clicked,  I'm going to make a Nyan Cat for k9, I know cats and dog aren't typically the best of friends but who can so no to a pop tart cat. My challge this time is nyan cat loves to fly so instead of being ground based she needed to be air borne, with that in mind I turned to rockets I mean after all her natural habitat is space so it was a no brainier.
Step 1Lanchpad- (Not the Duck :)
  • last photo ←
*WARNING , THIS COMPRESSED AIR AND PVC BUILD CAN BE DANGEROUS CHECK TO SEE HOW MUCH PSI YOUR PIPE CAN TAKE AND DON'T GET ANYWHERE NEAR THAT NUMBER BECAUSE IF THE PIPE BREAKS APART AND FLIES EVERYWHERE IT COULD CUT YOU LIKE A KNIFE *
Rockets with any type of combustibles would be a no-no in the dorm so I went with the more dorm friendly compressed air. I also
decided to make this at home that way I could test it out in the field and if all went well Nyan cat woud come back with me.
Materials needed for Lanchpad:
1/2 inch pvc pipe 17'should be plenty with some left over.
4 bolts
1 inch coupling
T pvc fitting
90 degree bend fitting
pvc cap
O-Ring
pvc cement
soda bottle
wire firing pin
Black and Decker workmate
air compressor
quick cupling for the air compressor going into the pipe and connceting to the air hose
 (In my case Wasp spray :( During testing got stung 11 times by yellow jackets in the ground)
As you can see from the photos the pvc Pipe was cut into sections and made a "T" shape using the two fittings and pvc cement mentioned above cap one end and add the quick cupling for the air compresser on the other end. Put a empty soda bottle on the pipe that is up on the 90 degree angle and mark it because your going to need to make a grove where you can slip the o-ring around. Next up, drill two holes in the 1 inch coupling where the wire firing pin and hold the top lip of the bottle. once that is done drill out four holes on the bottom of the same coupling for the bolts.  If your lost take a look at the pictures for additional help. Attach a rope or string to the firing pin.
The workmate will be used to stabilize the launchpad and add weight so it wont tip over.
35 comments
Jan 21, 2012. 8:30 PMwalgrimph says:
nynan nyan nyan nyan nyan yea that is AWESOME
Jan 13, 2012. 10:42 AMmonsterlego says:
NYANNYANNYANBOOM!!!
~~~~~~[__]^-^
Aug 6, 2011. 4:58 PMbeanieostrich says:
NYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYAN
Nov 1, 2011. 7:04 PMMatrix-technician says:
NYAN NYAN NYAN NYAN!!!!
-finds rocket powerup-
=============================x[][][][][]>
Aug 7, 2011. 8:59 AMRoddyTheGreat says:
NYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNYANNY
Oct 28, 2011. 11:30 AMsuperdude00 says:
LOL
Sep 18, 2011. 8:05 PMknexsuperbuilderfreak says:
i love you and this ible!
Sep 9, 2011. 5:58 PMNYANCAT says:
OMG!! I'M FAMOUS! :DDD Follow me!(:
Sep 2, 2011. 7:03 PMDumchicken says:
nyan nyan nyan nyan nyan nyan nyan nyan nyan nyan nyan nyan
nyan nyan nyan
nyan nyan nyan
Aug 25, 2011. 1:36 PMjmorrison-2 says:
is there a 10 hour version of this video yet?
Aug 14, 2011. 5:29 PMMrClin says:
Isn't that the the LulzSec cat?
Aug 9, 2011. 8:31 PMnsin1 says:
This is cool. Could i post this to Nyan Cat fans' site: www.nyan-cat.com? I'm sure thousands of fans there will like it. Credit will be given by linking to your site too. Thanks.
Aug 6, 2011. 1:22 PMxavec says:
Bwahah! There is no way this wasn't going to get my vote XD Outstanding work, friend!
Aug 2, 2011. 6:37 AMdombeef says:
Next, rocket engines!
Aug 5, 2011. 1:04 AMKryptonite says:
...NYANYANYANYANYANYAN - schfwooooooooooooof!!!
NYANYANYANYAN
Aug 5, 2011. 10:08 AMdombeef says:
Real NYAN CAT in space! Just get an old mp3 player with it playing nyan cat, a few solar panels so the battery would never die, and get a few speakers, though you cant hear anything in space, but it would still be cool!
NYANYANYANYANNYANYANYANYANNYANYANYANYANNYANYANYANYANNYANYANYANYANNYANYANYANYANNYANYANYANYANNYANYANYANYANNYANYANYANYANNYANYANYANYANNYANYANYANYAN FOREVER
Aug 6, 2011. 7:24 AMKryptonite says:
Huston, we have a ... wait a second...!
Aug 6, 2011. 7:32 AMdombeef says:
NNNNYYYYAAANNN
What was that?
Aug 5, 2011. 4:27 PMebrightside says:
nyan nyan nyan...
*launch*
NWWWYYYAAAAANNNNN!!
Aug 4, 2011. 8:11 PMCatTrampoline says:
Truly awesome! The best Nyan cat hack yet. Not that I've seen very many - just sort of shook my head at the dozen scrolling across my supervisor's screen one day.
Aug 4, 2011. 2:16 PMRickDick2 says:
True, dorms and fire don't mix, BUT try adding a little water in the bottle and maybe plastic streamers. I think you"ll like it!
Aug 4, 2011. 6:34 AMprojectsugru says:
yay, I love Nyan Cat :)
Makes me think that there should be Nyan cat kites, do they exist already ?... Or is that an Instructable for a kite guru?....
Aug 4, 2011. 10:42 AMmysss says:
You must make a nyan kite for us! To the internet!
Aug 4, 2011. 10:26 AMjamwaffles says:
Don't get me wrong; the concept, idea and write up of this Instructable is brilliant, but I'm so sick of that damn cat!
Aug 4, 2011. 8:23 AMbowmaster says:
This is awesome. Now I want to make a light weight speaker to mount inside to play the Nyan cat song from a lightweight MP3 player.
Aug 3, 2011. 10:46 AMESunde says:
nyan.cat
Aug 2, 2011. 12:58 PMZoDo says:
Nice. Go cat go !!!
Aug 2, 2011. 7:35 AMthe poodleo says:
even though you said you cant use combustibles, a great idea would simply be to mod a model rocket., because if you buy a nice one, you can get that Nyan cat to go really high. I might try it, and if I do, then I'll post a video
Aug 1, 2011. 10:05 AMSHIFT! says:
You should put a little mp3 inside of it, so it can blast music while it rockets!
Aug 2, 2011. 7:30 AMthe poodleo says:
THAT IS SUCH AN AWESOME IDEA!!!!
Jul 31, 2011. 7:33 PMDJ Radio says:
lol Nice ible.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:ahrshin
I'm just your normal college student, that likes to get his hands dirty in all type of projects.
