OBSTACLE AVOIDING AUTONOMOUS CAR
4,268
48
12
Published
Introduction: OBSTACLE AVOIDING AUTONOMOUS CAR
About: Electrical engineer by profession
Friends this is new version obstacle avoiding card with new features like LED Head lights with complete step by step details and video
so friends have a look and comment you like it or not.
so let see how to make this obstacle avoiding car by own.
Step 1: Video
guys have a look to video, this will help you to visualize how to make this autonomous obstacle avoiding car
Step 2: Material Need
Major item list with purchase link
DC GEAR MOTOR-----------------------1 set
http://amzn.to/2fvQwxu
TWO WHEELS----------------------------1 pair
http://amzn.to/2fvVXwl
HC-SR04 ULTRASONIC SENSOR--------1 no.
http://amzn.to/2fEVCa4
ARDUINO NANO-----------------------------1no.
http://amzn.to/2fEVQxW
L293D IC---------------------------------------1no.
http://amzn.to/2eeaG9c
MINI BREAD BOARD---------------------1no.
http://amzn.to/2fvV72S
9V Battery-------------------------------1no
Jumper wires------------------------20 to 25 pc
ON/OFF switch---------------------1no.
Acrylic sheet-----------------------1no
Double side tape-----------------as required
Step 3: Preparing Chassis
let see how to prepare chassis of the car
  1. This car is very simple don't need to buy any car chassis from market you just want a Acrylic sheet piece of size approx 5 X 12CM about 4 to 5 mm thick
  2. Stick the DC gear motor on the acrylic sheet as shown in image with the help of double side tape
  3. stick some hollow pipe or straw piece to the other end of the acrylic sheet
  4. Bring wheel from some old toy and pass its shaft from that hollow tube so that this wheel became rotate freely
  5. Place the wheel of dc motor to shaft of the motor.
  6. stick Ultrasonic sensor at the front end of the car with the help of double side tape as shown in imgae
Step 4: Electrical Schematic & Arduino Code
Connect all the electrical connection as shown in image, do this carefully because a sing mismatch of polarity can burn your arduino or L293D IC
also find the attached Arduio code download this code and upload to your arduino
as you can see in code at line number 35 [if (distance >= 15)] you can change whatever distance you want as safe distance here i kept 15cm is the safe distance you just have to replace 15 with you safe distance cm
So guys hope you find this interesting
please connected if any doubt
till tan by friends coming soon with new project
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    12 Discussions
    I've connected everything just as shown in your given circuit diagram, the arduino nano is communicating with the ultrasonic sensor but the motors aren't responding
    /* UPLOAD THIS CODE AND TRY
    #define ECHOPIN 6
    #define TRIGPIN 7
    void setup(){
    Serial.begin(9600);
    pinMode(ECHOPIN, INPUT);
    pinMode(TRIGPIN, OUTPUT);
    pinMode(11,OUTPUT);
    pinMode(10,OUTPUT);
    pinMode(9,OUTPUT);
    void loop()
    digitalWrite(TRIGPIN, LOW);
    delayMicroseconds(2);
    digitalWrite(TRIGPIN, HIGH);
    delayMicroseconds(10);
    float distance = pulseIn(ECHOPIN, HIGH);
    distance = distance/58;
    Serial.print(distance);
    Serial.println(" cm");
    delay(50);
    if (distance >= 15)
    {digitalWrite(11, HIGH);
    digitalWrite(10, HIGH);
    digitalWrite(9, LOW);
    else
    {digitalWrite(11, LOW);
    digitalWrite(9, HIGH);
    delay(2000);
    // code end
    Very nice project but could you please send pictures of the wiring and where and how the ultrasonic sensor is connected, Thank you
    hi MNM_25-07 i have updated the complete wiring drawing above, also i am attaching a pic with this replay for your better understanding
    very nice friend,
    is it possible to show the wireing in pictures or video for beginners?
    hi WannaDuino i have updated the complete wiring drawing above, also i am attaching a pic with this replay for your better understanding
