OMG! Through the Table!
212
Posted in TechnologyArt
Introduction: OMG! Through the Table!
Step 1: View Me!
Materials:
- Autodesk 3D Max
- Computer
- Video Reference
- Mouse/Stylus pen &Tablet
- List and description of the 12 Principles of Animation (just for reference)
- Two rigged characters: http://www.turbosquid.com/ or http://www.creativecrash.com/ They have some free 3d character models.
Step 2: Create Environment
Lets start with the environment!.
When 3D max is opened, you can find the tools needed on right-hand side under object type.
 - To create the ring, just create a box the size of your choice.
 - To create the ropes, use cylinders and make it the width and length that fits the ring.
 - The padding, where each rope meets, is created with spheres that have been stretched using the scale tool.
 - The padding are held by a horizontal cylinder which is connected to the big verticle cylinder.
 - The table is made with boxes as well (2 so that it will break easily).
Step 3: For Your Info
If you look at the bottom of the screen, you will see the time slider. Look for these four features. Auto key, Set key, key filters, and this square that has a key icon on it. Select key filters and select all.(this allows you to animate all attributes that can be animated).
I use auto key because it automactically records everything I do on each frame :). Set key requires you to record manually :(.
The square that has the key icon can be used to manually record during auto key mode.
However, it is mainly for set key mode because its the only way you can record in that mode.
You must select either modes first and the timeline must turn red first before you can use
the square key icon or record animation.
You will notice that a square box is made on the time slider when you create a keyframe. The closer key frames are together, the faster the action. The farther they are the slower an action.
Step 4: Let's Animate
Now its time to animate
 - First thing I did was pose everything at its starting position.
 - Second, I created an anticipation pose. I bent the knees of the guy in the (red shorts) so that it looks like he's about to jump.
 - Next, I posed the man in the (red shorts) at the peak of his jump
 - Then I made a contact frame. This frame is very important, as it creates the cause and effect of an action. So now we know why the table broke.
Step 5: More Poses
 - After the contact frame, I created the reaction frame. This is in response to the action that was just performed.
 - If you look at the photos in there respective sequence, you should see an idea of what the animation will look like.
 - Sometimes different parts of the character floats or move at the wrong time. Usually the previous key frame stops that phenomenon.
 - To fix unwanted movements, I select the previous key frame and copy it (hold shift, then drag to copy). I place the copied key frame inbetween the previous pose and the next pose. Then I animate a little on the copied key frame so that it don't look like the previous key frame as much.
 - After I review the poses and key frames, I select the whole character's rig and space out the key frames on the time line so that the action is fluid like. Smooth animation= good !, choppy animation= bad !
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    2 Comments
    very cool, I didn;t realize that's how it's done (with keyframes). makes much more sense now, thanks!
    Thank you for viewing and I'm glad you were able to get something out of my video. :)
