loading
Every OMR Software works on integration with an ADF scanner. Once you scan all of your OMR Sheets using scanner, OMR Software reads those images and extract data out of them.
Here we'll use Smart Reader, an OMR reading software mostly used by major examination bodies of India.
Step 1: Template Creation in OMR Software
Template Name
 - Specify template name here
Description
 - Write description of the template
All multiple answers
 - Allow this option, if you're having multiple answers in Questions
Number of questions to check
 - Enter the number of questions to check on response sheet
Page - 1
In this option, specify whether a response sheet is single sided or double sided printed.
Rectangle Orientation
 - Enter the orientation of timing tracks that may be left/right/both.
Rectangle margin
 - Enter the distance from Timing tracks to cutting edges of omr sheet.
Rectangle Counts
 - Number of rectangles in timing tracks.
Click here to add image
 - Here add front side of the black and white image of omr sheet.
Page  - 2
Fill this option, if you're response sheet is double sided printed or having timing tracks on both sides
And finally click Save button.
About This Instructable
3,110views
5favorites
License:
More by Rakesh007:How to check omr answer sheets quickly ?
Add instructable to:
