This is a really simple split power supply Op Amp PWM, only seven circuits. The large heat sink is necessary. The parts are easy to get too.
Remove these ads by
Signing UpStep 1Building the Circuit
As you can see it is small and simple. The pot should be at least 20k, and the more powerful transistor you use the better. A 1nF cap will produce 8 kHz oscillations a 150pF makes 75 kHz but the lower the capacitance the less reliable the circuit is. You can find your happy medium. =] The yellow leads go to ground and the load. The LED's are for the diagnostic circuit.
Additionally, doesn't the transistor need a base resistor? I know that using a lower power transistor without a resistor on the base, breaks it, is it not the same for high power transistors?
