Oak clock made with router
 by videre
Featured
This oak clock I made with wood from a tread from an old staircase, the same wood as I used for this cutting board
Materials:
- Wooden oak board
- Clockwork
- Keyhole hanger (incl. screws)
- Piece of wood cut in 60 (or 30) degree angle for measuring positions of hour markers
- Raw linseed oil (Be aware that rags used for applying linseed oil can spontaneously catch on fire, so make sure to dispose of them properly)
Tools:
- Router
- Straight router bit
- Round router bit
- Planer
- Drill
- Fine grained sandpaper
- Screwdriver
Process:
First I cleaned up the board using a sharp piece of metal on a handle to scrape off the top millimeter. This was necessary because the board surface was in bad shape (sand, pieces of glass), and I didn't want to damage the planer.
After that I put it through the planer.
The round shape was cut using a router with a circle cutting jig and a straight router bit. I had to do .5cm depth at a time since that's what the router could handle.
The hole in the back for the clockwork was made with a straight router bit.
The individual hour markers were made using a rounded router bit. The darkening of the wood was a coincidence and a result of the router bit burning the wood a little. To find the exact spot for each marker, I first used a regular squares tool for the hours 12, 3, 6 and 9. I then cut a 60 degree angle piece of wood and drew the lines for the rest of the markers based on that and the existing lines.
After routing the hour markers, I then treated the wood with raw linseed oil.
The clockwork I inherited from my grandmother who used to make clocks out of old vinyl records. There was also a red second hand, but the color didn't fit with the wood, so I left it out.
Finally I bought and attached a keyhole hanger. I first drilled about .5cm into the back to allow space for the screw head when hanged and then attached it with two small screws.
M3G says: Oct 21, 2012. 11:00 AM
Great work, keep it up!
videre (author) in reply to M3GOct 21, 2012. 2:19 PM
Thank you, I hope to have time to post more soon.
Codswallop says: Oct 21, 2012. 1:19 PM
I have been saying for a while that I need a clock for my workshop. Thanks for a quick, handsome how-to. I hope to get to this project next week.
videre (author) in reply to CodswallopOct 21, 2012. 2:16 PM
Sounds good, I would love to see it when you finish.
pudtiny says: Oct 20, 2012. 10:46 AM
nice job, sometimes simple is best. Its maybe worth mentioning that rags used to apply linseed oil can get hot and ignite when drying if left scrunched up. I leave mine laying out flat to dr. Strangle but true fact
videre (author) in reply to pudtinyOct 21, 2012. 11:10 AM
That's a good point, I had a vague memory of hearing this somewhere, but stupidly ignored it. I have now properly disposed of the rags, and will include a note in the instructable. Thank you!
audreyobscura says: Oct 19, 2012. 11:12 AM
This came out really nice. Thanks for the share, I love upcycling materials.
videre (author) in reply to audreyobscuraOct 19, 2012. 11:32 AM
Thank you, I try to only use wood that others threw out or gave away.
It adds an interesting constraint to what I can do with it since I don't choose the shape or form that it comes in.
In this case it was a 100cm by 20cm rectangular piece of wood, so no real constraints to speak of except that I wanted to find a use for the clockworks I just inherited.
I still have three more, and I'm looking for inspiration if anyone has ideas.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
