Oblivitus' K'nex Ultra Pistol
6,740
14
138
Published
Introduction: Oblivitus' K'nex Ultra Pistol
About: I paint, write music, and used to build knex guns. I have a Bachelor's Degree in Studio Art. - updated 5/7/2014
DON'T BUILD THIS, BUILD THE ULTRA PISTOL 2
Description: More powerful, accurate, stable, part efficient, and comfortable than the Super Pistol, this gun has been engineered to death as a single shot and is my most reliable k'nex weapon. The front half of the barrel is now also super light so that it still can be easily aimed and fired with one hand. This instructable was all done with MLCad. I have already made a new upgraded version of this gun with a 6 round hopper but I did make this in physical form before making the computerized version.
Influences: Loosely based on Jollex's DD-27 Pistol.
Length: 13 inches (longest section)
Width: 3 inches (widest section)
Height: 3.5 inches (tallest section)
Max Accuracy: 5 inch target from 10 feet.
Rate Of Fire: Load, cock, and fire.
Ammo: Gray rods.
Max range: 35 feet.
Features: iron sights, true trigger
Flaws: None.
Note: This gun uses 1 cut part, office tape, and duct tape.
Click here if you want to make 3D knex models:
https://www.instructables.com/id/Making-3d-knex-models-using-mlcad/
Step 1: Handle
1: Make this.
2: Make this. Add it on top.
3: Make this. Add it on top.
4: Make this.
5: Connect as shown.
6: This is the finished product.
Step 2: Handle/Barrel Merge
1: Make this.
2: Make this.
3: Make this.
4: Add them together.
5: Add a blue rod.
6: Make this.
7: Add it on.
8: Add a blue rod with a tan connector.
9: Add a gray connector.
10: Add the sections from step 1 and 2 together.
Step 3: Trigger Area
1: Make this.
2: Add green rods and a blue connector.
3: Make this. (The black pieces represent Y connectors.)
4: Add on the part from picure 3 and add 2 gray connectors to each side.
5: Add 3 blue spacers.
6: Add a ball socket connector for the back sight.
7: Make this.
8: Attach it.
9: Make this.
10: Make this. (The black piece represents a Y connector.)
11: Attach 9&10.
12: Make this.
13: Add the new pieces to it.
14: Attach it.
15: Make this.
16: Make this.
17: Add 15&16 together.
18: Put a green rod in the 45 degree connectors and cover the holes on both sides with office tape or duct tape if you don't have office tape.
19: Add a green rod to the top of the orange connector and cut it in half with scissors. (This may take several minutes if you have never done it before, it now takes me about 30 seconds because I have done it a few times.)
20: Attach trigger mech to gun.
21: Attach the 2 sections.
22: Make this.
23: Add it to the gun.
Step 4: Barrel
1: Make this.
2: Make this.
3: Attach 1&2.
4: Make this.
5: Attach 3&4.
6: Attach to the rest of the gun.
Step 5: Firing Rod
1: Make this. (Add duct tape the same way as on my Super Pistol.)
2: Put it on the gun and add elastics through the hole in the orange connector, stretch them to the blue rods closest to the front of the gun.
Congrats, the gun is finished.
Step 6: Need Help?
Message me if you are having trouble.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Pets Challenge
      Pets Challenge
    138 Comments
    What's the best type of rubber-band for this gun?
    By the way, It's the best long-barreled pistol i've seen on the web and DEFINITLY the best gun i've ever made.
    is there anything that could replace the blue and green things on step 15?
    THE ULTRA PISTOL 2 HAS BEEN RELEASED
    CHECK IT OUT!
    Well, I made this gun to get revenge on someone, but wow, after finishing it, that would be cruel XD It took awhile, but I finally found a good rubber band that doesn't put stress on the firing rod, but it is still pretty powerful, and best of all, I can cock it back in less than a second. I love style of the gun:Super huge pistol, or shotgun. Love it. Also,I found it fires farther when the bullet is in the middle of the barrel, not pushed all the way back.
    I made the barrel slightly shorter, and it actually improves accuracy and power a lot! Though with my new barrel design red rods fly the best, grey rods still work to, and since they slightly stick out the front of the barrel you can aim the gun up and down without worrying about the round to got loaded in falling out.
    The Ultra Pistol 2 has been released. Check it out!
    I chose to make this one over the Beast pistol only because of the one-shot-then-load system I have much luck with in K'nex wars. When I told the 5 friends I shot with it at long range (14 feet to 20 feet and hit them) that I got this off Instructables from a guy called Oblivitus, they logged in, looked at your weapon supply, and stated, quite simply: "We hereby ban any weapons made by Oblivitus from the battlefield for being too powerful." I told them, "It's your fault for not stating the rules before that some guns are too strong." They replied: "We didn't know you were bringing the tank."
    shoot them with the real DD-27, or the SR-v1, maybe the BR-v1 next time.
    I intend to. Or perhaps a version I've been working on for a very long time: single shot, firing similar to the SR-v1 (is that the one with the nail in the knex piece, firing Slingshot style?) complex multi-linkage True Trigger design, and is dependable in how it loads and shoots. Problem is, it's uglier than sin and has a high-length loading time. The bonus, though, is that it spits yellow bolts (more yellow than red w. me) at 250 FPS measured by a chronograph.
    one of the best guns i have made
    Thanks, I have a version 2 built and I will be making instructions for it sometime.
