Obstacle Avoidance Robot
Introduction: Obstacle Avoidance Robot
In this instructable I will be showing you how to build, program and tweak your very own robot. The main board we will be using is an arduino uno. This is a micro controller that we will be programming with our computer. The robot will be able to move, and once it has found an obstacle it will either turn left or turn right then continue forward.
Arduino Board
dual H-bridge ( I used the L298N h bridge)
car base with two dc motors
one ultra sonic sensor (HC-SR04)
one LiPo battery ( use one between 400-600 mAh)
One portable USB charger to power the arduino
On/Off switch
screws and zipties to hold all the electronic components in place
Connector wires
Step 1: Connecting the Components
Connect all the components according to your h-bridge terminals.Remove two PWM (pulse width modulation) connectors, this will allow the motors to go forward and backwards Remember, when turning on your robot, the switch has to be in the on position and the arduino needs to be powered up. Connect the ultrasonic sensor, power to 5V and ground to GND. Trig pin connects to pin 5 on arduino and echo connects to pin 4 on the arduino board.
Step 2: Downloading the Code
Download the code and upload it to your arduino and make sure the robot has two power supplies. One to power the arduino and one to power up the H-Bridge. Place you robot on the floor and watch it go. Here is the video on how the robot moves around.
If you liked this project, please vote for it in the circuits contest. That would really show your appreciation.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    The project is good.
    Just a suggestion, whenever you are taking pics, be sure to have enough lighting around. That helps us to understand it better.
    Keep up the good work:)
