Odds and Ends - Interlocked Shelf
3,580
90
Published
Introduction: Odds and Ends - Interlocked Shelf
About: I am a retired Electronic Systems Engineer now pursuing my hobbies full time. I share what I do especially with the world wide student community.
I have a lot of electronic 'odds and ends' and was triggered by the Instructables shelving contest to organize these using a simple interlocked shelf.
I wanted to manage with 3 pieces of very old plywood (more than 20 yrs old). One 3'X18"X1/4" and two 4'X18"X3/8".
I was aiming for 7 horizontal shelves 4' wide and 4" depth.
While I show the construction process in the next few steps, this project has taught me several lessons:
  1. Avoid using old plywood as the layers tend to peel off while working.
  2. I marked of the grooves for interlocking using one of the vertical/horizontal pieces as a template rather than accurately marking the grooves. Landed up with some misalignment.
  3. Corrected this by widening the grooves and had a very loose fit which needed the grooves to be packed with wooden shims.
  4. I initially thought that the vertical and horizontal members when nailed would be rigid enough. However I had to reduce one horizontal shelf and use the left over material as long gussets at the rear. Working with thin plywood probably needs a full sheet at the rear.
  5. Cutting the plywood leaves edges with burr which needs to be sanded out.
  6. Ordinary plywood is rough and needs putty and paint to get a professional look. Need to do this later.
However, in spite of several ups and downs I have managed to put together a practical interlocked shelf and filled it up with my electronic odds and ends.
Step 1: Starting Point
I started off with my jam bottles and assorted plastic containers in which are filled my electronic odds and ends collected over several years which need to be accessed at random times in a random fashion as my current project demands.
No purchasing any new material, I decided to make do with some 20 year old plywood pieces which were originally shelves in an old house which was remodeled. One 3'X18''X1/4" and two 4'X18"X3/8" pieces
Manage with a minimum of tools. Electric saw for cutting, chisels for minor carpentry and a hammer for nailing the shelves together.
Step 2: Horizontal and Vertical Members
I cut 7 pieces of 4'X 3 3/4" for the horizontal members and 4 pieces of 3'X 3 3/4" pieces for the vertical members.
I planned to have two vertical sides and two internal interlock pieces along with 2 top/bottom horizontal shelves with 5 internal interlocked shelves.
I marked of one each of the vertical/horizontal pieces and used it as a template to mark off the other pieces.
I cut the grooves in the interlock pieces with the saw and finished off the ends using the chisels.
Step 3: Assembly
I first made a trial assembly to check out the interlock joints. I found several miss-alignments and the grooves being wider than required. The over scheme also lacked rigidity.
I then decided to remove one horizontal shelf and use it along with other left over material as a rear support for the shelves. This worked out well and when everything was nailed together the shelves were rock solid.
Finally I finished off the hanging arrangement by providing 3 holes for for fasteners.
A quick job of sanding removed the excessive burr and the shelf was ready for fixing and use.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    3 Comments
    Also, I meant to say, the end product looks great.
    Good job. I like that you were able to rework your plans to get a solid product. Thank you for letting us know about that rework, that helps others understand how fluid a project can be and that faults in the original plan don't need to be faults in the end product!
    Nice shelf. It's always interesting to see projects using minimal tools and existing materials. Also it's refreshing that you told us about your your mistakes. Thank you for sharing.
