Office Booby trap
Step 10Fixing it down
Fixing it down
When you set your Booby Trap you are going to want to stop it moving about and remove the possibility of being pulled over by the Trip Wire.
To give you the ability to fixed down make 4 holes. Two on one side of the Bottle Top and two on the other. Then thread some string through the holes and tie a knot.
All you need do now in order to fix your Booby Trap in place is to either Sticky Tape the string down, or use the two Drawing Pins like in the picture below.
This also gives it the ability to be fixed vertically to a door frame etc.
3 comments
Jun 21, 2010. 9:54 PMMFPOSGBCS says:
how do you put on the projectile???
Mar 9, 2010. 2:46 PMmechanical mayhem machine says:
 or duct tape it
Nov 9, 2009. 5:32 PMthe "wow shammy" says:
you could just hot glue it and then if you wanted to move it you could rip it off and glue again. once the hot glue is every where you could just peel it off.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
115
Author:PocketSized
