3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Office Chair Bike
Office Chair Bike
  • C:\Documents and Settings\HP_Administrator\Desktop\officePush[1].jpg
  • C:\Documents and Settings\HP_Administrator\Desktop\OfficeCAD[1].jpg
  • C:\Documents and Settings\HP_Administrator\Desktop\OfficeMiter[1].jpg
  • C:\Documents and Settings\HP_Administrator\Desktop\OfficeStrap[1].jpg
  • C:\Documents and Settings\HP_Administrator\Desktop\OfficeWelded[1].jpg
A recumbent bike with a very comfy seat.
It's a 35 pound leather executive office chair connected to a 16" (little girl's) Princess bike re-welded into a recumbent (recliner bike) and using a piece of another donor bike frame.
I built it in honor of "Bike to Work Day".
If you like fun/unusual home built bikes... check out my hobby site Woodenbikes.com
Step 1Design your bike using a CAD system (Cardboard Aided Design)
Make a cardboard cutout of your lower leg (with foot and pedal), thigh, torso, and straight arm (to a distance 2" back from your wrist). Use it to look for good riding position and clearances for knees to bars, heels to wheels etc. Use the CAD system to layout the riding position, cranks, wheels etc with attention for locating your hands, shoulder, seatback angle, butt, knees and feet. Also look for ways to arrange a straight chain line (at least for the tight side) by raising the Bottom Bracket (BB)(main crank bearing).
For detailed instruction on designing a sweet handling recumbent visit www.bikesmithdesign.com
50 comments
1-40 of 50next »
Apr 23, 2012. 2:11 AMDRH1469 says:
Cardboard Aided Design = CAD hahahahahahahahahahahahahahahahahahoooohaaohoohohahahahahahahahoooohahahhhhaaaamwhhahahahahahahahahahhaaghahahahhaahhahahahahahahahahahahahhahahahahahahahahahahhahahahahahahahahahahahahahahahhahahahahahhahaha,COUGHHHHHhahahahahhahahahahhahahahhahahahahahhahahahahahahahhahbwhahahahahhahhahahahahhahahahhahahhahahhahahahhahahhahahahahahhahahahahahahhlmfaolmfaohahahahahahahhahahahhahahahrotfolhahahahhahaarotfolrotflalmaohahahahhahahahahahhahahahahahahahhahahahhahahahahahahahhahahahahahahahahahahahahhahahahahhahahahhahhhhhhaaaahhhhahhhahahahah>>>CHOKE CHOKE CHOKE CHOKE DIED DIED DIED
(This is what happens when you LMFAO)
Well Done none the less
Apr 24, 2011. 2:25 PMHanzieO says:
Hi, I stole some of your ideas, from this site and your own, and made this bike from a bit of Origan I found, some plywood and a junk yard 20" kids bike. Great work keep it up. You inspired me to re-use and recycle.The seat is foam padded and uphulstered with yellow vinyl. I also adde a lightning bolt and a scull sincce the foto.
Apr 26, 2011. 1:34 AMHanzieO says:
Thanks. You are right about the weak headset connection. Its the bit that worries my the most(structually).
I drilled the hole a bit oversize and filled it up with Epoxy resin. But I can see about 10mm movment on the front wheel axle if I brake hard. Today I got a big tube of 2part epoxy putty and built it up above and below. seems to help. I will keep an eye on it and if that fail I will weld a piece of plate on underneath and screw it to my beam.
I am halfway with the next one. Its a bent plywood one like the one seen here on this site. Instructable soon!
Apr 28, 2011. 2:46 AMHanzieO says:
http://www.instructables.com/id/Wood-Bike-2/
Jul 30, 2009. 1:29 PMElvenChild says:
You claim that your fashion sense is bad believe me mine is 3 times worse it involves a long sleeve green shirt and fuzzy number 18 soccer pants
Jul 20, 2007. 4:55 AMDzwiedziu says:
How did you mounted the chain? The instructable lacks in explaining this. I'm not a fan of horizontal bikes l but you still deserve a + for the Carboard Aided Design and pointing out the ecological issue.
Apr 21, 2008. 8:49 PMsrhadaham says:
my drafting teacher must not know the real meaning of CAD cause for some odd reason he refers to it as computer aided drafting, wonder where he came up with that incorrect acronym
Jul 30, 2009. 1:24 PMElvenChild says:
He's probably thinking of the cademia program cad for short. And by what do you mean acronym.
May 3, 2009. 2:22 PMReCreate says:
Have you ever fallen down? How bad is it when you fall down?(it looks to me that your hit the ground either from the side(a tipover) Or you fall forwards(Hit something))
May 4, 2009. 11:26 AMReCreate says:
Oh,ok
Jul 20, 2007. 8:06 AMrimar2000 says:
Excellent design. I envy you. The only objection is that the fork of the front wheel seems something weak to support the weight of a mature person (and quite robust).
May 3, 2009. 2:24 PMReCreate says:
Um...what?(the last 2 words)
May 3, 2009. 1:19 PMBryan Smith says:
Pocket Protector! My Dad is an engineer and uses pocket protectors too!
Jan 7, 2009. 3:32 AMDuctTapeRules! says:
I've used CAD before, pretty useful and much more easy than the other CAD (computer aided design). There's also my favourite method of, "stacking up random crap from around your work area/little part of the dining room until to simulates the height parts need to be" :P.
Cool bike, too
Oct 23, 2008. 11:06 AMcoolguy says:
You should get one of those mini chain link steering wheels (like the ones that latinos use on custom bikes and are just small enough to allow you to steer it with handcuffs on) to use for steering. It would solve the turning radius issue and make it that much more awesome.
Like This
May 1, 2008. 11:58 AMAngusNotSoYoung says:
That's pretty cool. I can tell you're an engineer by the way you layed everything out in cardboard ahead of time (Step 1-2). Judging by the picture in step 8 it doesn't look like you have a very tight turning radius. Good Instructable.
Apr 19, 2008. 11:37 PMYerboogieman says:
i thought about this a couple days ago when i rode into town on my bike, cause it was 5 miles, all i could think about was the padding on this bike, that could have let me sit down with out anything hurting
Dec 7, 2007. 4:59 PMgreenjedi says:
HAHAHA! i actualy had this idea awhile ago, and now its here on instructables, thats crazy!
Mar 23, 2008. 8:06 PMpyroman50 says:
that would be awsome if you made a office chair scooter
Dec 16, 2007. 12:01 PMbedbugg2 says:
oh man...if you fall of that youre screwed
Nov 15, 2007. 7:40 AMOffice Chair UK says:
I am very impressed with your office chair bike. It has the most comfortable seat I have ever seen on two wheels although I am concerned about its stability and the pressure on your legs. But you say you're able to ride 15mph on flat surfaces, so that's cool.
I like the idea of encouraging the local dumps to set up exchanges - I don't think that any such exchanges are available in the UK at the moment. Keep up the good work!!
Office Chair UK.
Jul 21, 2007. 4:48 PMIdahoDavid says:
Sweet. But is it ergonomically correct for using your keyboard? It really needs a place to bungee-cord a laptop and printer, a coffee cup holder, a phone/answering machine and perhaps a two-drawer filing cabinet. Think of the advantage of attending meetings. Your workspace would be right there with you and all you would need is the donuts.
Aug 30, 2007. 12:54 AMnaught101 says:
dude, that WOULD be cool - forget the paniers, strap on some filing cabinets!
Aug 24, 2007. 6:46 PMdkfa says:
What if you fell? You cant get off fast.........but I understand the office chair theme
Jul 27, 2007. 12:17 AMquadleader says:
where i live we have this place called the exchange, its where all of the stuff that may still be usable by others goes, bikes cameras computers all kinds of stuff its really cool i actually got my bike there and a digital camera a macintosh (power mac g4) so then you dont have to go dumster dipping.
Jul 27, 2007. 1:43 PMTheBikemaniac says:
I built a similar project last week with a kids bike and a really grotty old 70's chair I found in the garbage and I managed to get the huge orange and brown chair right over the wheel by instaling sissy bars so I could manage to pedal on the original pedals. Just yearsterday I installed a ten speed bike fork and I installed a weed eater motor to the back wheel under my seat. It's one funky ride! Sorry for my spelling I'm french, oh and I really like your bike, looks much more cumftabale then my'n, one question, do you have a weelie problem (the bike keeps falling one It's back) couz I do?
Jul 27, 2007. 1:11 PMrjnerd says:
The Buscycle used office chairs for most of its seating (to my great dismay, at least I talked them out of the minivan seat track adjusters). One problem is that any chair that provides enough thigh support for comfortable sitting, interferes with your legs when trying to pedal. You need to cut the seat pan much shorter. Your photo alludes to this, showing you perched on the lip, well away from the actual back.
For the buscycle I designed them a simple and light open frame seat made from conduit and the fabric for "directors" chairs. The narrow strip of the directors "back" formed the seat, and what was the seat bottom, was used in the back of the thing. Took under one man hour to cut/bend/miter/weld the frame. Took more than 3 hours to adapt the office chairs (including shortening the seat pan).
Otherwise its a good example of the "10 cent bent" style, and a great thing for bike-to-work week.
-dp-
The NERDS
Jul 26, 2007. 4:00 PMgannon says:
Hi--Is this functional, or does your father-in-law have to push you everywhere?
Jul 20, 2007. 3:30 AMmikesty says:
I am exceptionally jealous of your coolitude. Stuff like this only comes in my dreams. You can make it a reality. I can't. That's cool. I would probably buy that if I wasn't so poor.
Jul 21, 2007. 2:01 PMmikesty says:
How much engineering experience do you have? I just turned 18. I'm going to college next year to study engineering. I've done robotics for the past two years but I never really worked with machinery and I am not always a hands-on guy. I'm a bit of a late bloomer, but I think that some day I'll be able to make one :) Currently I've got this old Panasonic Villager III bike I'd like to repair and take with me to college.
Jul 26, 2007. 3:00 PMjridley says:
The most important thing anyone can learn is to embrace failure. Half the stuff I build doesn't work at all or not very well, but even so it's fun, and the stuff that does work, doubly so! Many times I'll build something knowing full well that it won't work; I'm doing it so that I can learn what the pitfalls are, what areas need special attention, etc, so that my next attempt will work better.
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:Woodenbikes(Woodenbikes)
Long time bicyclist, bike commuter, bike tourer, recent bike builder/experimenter. My day job is as an energy planner for a small utility. I specialize in hydro electric, other renewables and gas fire...
more »
