Office Room Temperature Logging With PcDuino and Yeelink Server
Published
Introduction: Office Room Temperature Logging With PcDuino and Yeelink Server
pcDuino can connect to Internet by Ethernet, WiFi, GPRS and 3G. In this project, we will see a TMP36 temperature sensor to sense the office temperature and push to yeelink server, and check the temperature anytime anywhere through the Internet.
Step 1: Part List
1  x  pcDuino V2
1  x  TMP36 sensor
1  x  Breadboard
1  x  3.3k ohm resistor
Several jumper wires
Step 2: Connect the TMP36 to PcDuino
The first figure is the bottom view of  TMP36. The corresponding pins from the left to right are VCC, VOUT and GND.
We connect TMP36 to pcDuino in the following way:
VCC of TMP36 -> 3.3V of pcDuino
VOUT of TMP36 -> A5 of pcDuino
GND of TMP36 -> GND of pcDuino
Add a shunt resistor between VCC and GND of TMP36 to prevent damage of components.
Final Setup:
Step 3: Sample Code
#include
#define aref_voltage 3
const int tmpPin = A2;
char buffer[50];
int tmpReading;
void setup(){
void loop(){
    tmpReading = analogRead(tmpPin);
    printf ("tmpReading = %d\n",tmpReading);
    float voltage = tmpReading * aref_voltage;
    voltage /= 4096;
    float tmpC = (voltage - 0.5) * 100;
    sprintf (buffer, "{\"value\":%4.2f}\n", tmpC);
    FILE* fp = fopen ("/home/ubuntu/datafile.txt","w+");
    fwrite (buffer, sizeof(char), strlen(buffer), fp);
    fclose (fp);
    exit (0);
Step 4: Compile the Code
Refer to book to check how to run Arduino style code in command line.
Create a file named tmp_yeelink.c. You can download the code from tmp36_yeelink.
Put the tmp_yeelink.c file to the sample directory under the c_environment which you just obtained from githun .
$ cp ***/tmp36_yeelink.c ***/c_environment/sample
***is the file you save the c_enviroment and the path of tmp_yeelink.c
Then modify the Makefile:
$ vi Makefile
Add the tmp36_yeelink after OBJS+= ***
OBJS+=tmp36_yeelink
Save and quit, input make and start to compile.
$ make
Then we will translate the analog value from the sensor to actual value of temperature, and save into a file named ‘data_file.txt’ in JSON format.
Step 5: Send Data to Yeelink
Curl is an open source communication tool which uses the URL approach in command line.
Create a script file named the yeelink.sh, then write the following code to the file. (Modify the corresponding APIKEY and URL according to your own condition, and as well as the path to  the file named tmp36_yeelink)
$sudo /home/ubuntu/c_enviroment/output/test/tmp36_yeelink
$curl --request POST --data-binary @"/home/ubuntu/datafile.txt" --header
Add the execution right for the script after you save and exit the file.
$ chmod +x yeelink.sh
–request <command> specify use command
–data-binary in binary POST data
@”…” cooperatively use with last command, to POST the content behind the @ to the server.
–header The custom header information is passed to the server
Step 6: Periodically Push Data to Yeelink Server
We will use a task called crontab to periodically push data to yeelink server.
Launch crontab editor by using:
$crontab -e
Add the script name as shown below:
Note: You should use yeelink.sh instead.
Step 7: Result
First measure the temperature of the office using a thermometer:
Then view the monitor state in the yeelink website:
The corresponding curve is our monitor temperature in the office.
If you want to learn more about the pcDuino jump to :http://learn.linksprite.com/author/yanny-guo/
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
