(You could make it using only office equipment - but the nuts and bolts hold things together better and make for a more accurate copy.)
It can be used to trace drawings and even enlarge or reduce drawings.
This one is made from:
- 4 x wooden (30cm) rulers
- 3 x nuts and bolts
- 2 pens
- a blob of Blu-Tack ( putty like substance that sticks to things)
- you will also need a drill and drill bit to make the holes.
Remove these ads by
Signing UpStep 1Drill the holes in the Rulers
( Make sure that the bolts fit through and can be fastened as well)
Drill 3 holes in each ruler. One at each end and one in the middle.
Be careful - start drilling slowly as the thin wooden rulers can split easily.
4
comments
Add Comment
snideprime
says:
murak (author)
says:
susanrm
says:
Add Comment
