Relax... there is no need to fret!
This transition from the online world into the real world is made easier by these things called "stamps." Like the similarly named "stamp" tool in Photoshop, a stamp allows you to replicate an image over and over in your file (or "environment," as they often call files in the real world). Now you can easily engage in the actual world with the same repetitive and meaningless interaction that would normally exclusively be reserved for the internet. Does it get any better than this?
(on a side note, none of this commenting behavior is encouraged on Instructables.com. Cut it out kids!)
Remove these ads by
Signing UpStep 1Go get stuff:
A (totally awesome) Epilog Laser Cutter
High-Quality Laser Rubber
Self Inking Stamp Pads
Corel Draw
A paintbrush
An Exacto knife
Note to hand-carvers: you can print your comments in reverse - use a laser printer, not inkjet - and transfer to rubber by placing your print face down on the rubber and rubbing the backside of your laser print with solvent. The laser toner will dissolve a bit and leave toner on the rubber as a guide to carving.
it is theoretically possible, but i won't win it....
...might want to correct that :-P
