3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Oil lamp with three matches
You can make an oil lamp from just three matches. This is also a good way to recycle used cooking oil. Most oils will burn well in this type of oil lamp and three matches tends to be the magic number to get a good lasting flame.
What you need are:
1.  A book of paper matches.
2. A piece of wire, like a twist tie or copper wire.
3. A bowl or jar with cooking oil in it.
Assemble by tying the three matches together with wire and make a loop so they will stand up in the oil. Then put them in the oil and light.
Step 1Tie together matches
14 comments
Apr 2, 2012. 3:40 AMashtigercub says:
Should the wick be completely immersed in the oil? :/ Or is the top out?
Apr 5, 2012. 11:26 PMashtigercub says:
Oh okay. Thanks :)
Dec 23, 2010. 10:28 PMThaikarl says:
very nice. very easy. we used to make a lamp with a shoelace hanging off the edge of a saucer of butter. once the thing gets warm, the butter melts into oil and feeds the shoelace wick. (where were in a place where they turned the lights out at 10pm and we didn't have flashlights) this would have been easier.
May 18, 2011. 6:54 AMbowow0807 says:
i did something similar using candle wax and a bbq stick. when the wax melted i coated the stick with it and then i lit the tip of the stick using the candle and voila a lighting stick and be careful because when the wax north of the stick melt and when it reaches the flame it ignites and makes a great drop of liquid fire effect
Jan 8, 2010. 12:06 PMIlluminati says:
Doesn't the burning of cooking oil cause a large amount of black soot to be formed? Shouldn't you be using lamp oil?
Apr 25, 2010. 4:08 AMknektek says:
if you are worried about soot, use oxygern, blow it on the flame
Apr 25, 2010. 9:25 AMknektek says:
well... what happened?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:steam_cannon(michaelcasper.com)
Hi There! I'll tell you a little about myself. I'm a maker and doer. I like sharing my experience, building hardware projects and all kinds of art. I enjoy woodworking, pottery, fibercraft, metalworki...
more »
