3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Oil, oil filter and air filter change on a Citroen C3 2006-2008
The Citroen C3 is a nice car, my only real grumble currently is that there is no Haynes manual out yet and it keeps being delayed.
So I'm writing up some of my notes as instructables on things as I do them, this should be a basic guide to success but hopefully the comments will help give some hints and tips of how to do things quicker and easier.
Tools:
  • 15/16" Socket - For the sump plug, I think 22mm is the exact size but I didn't have one.
  • 27 mm Socket  - for the oil filter housing.
  • Old washing up (or shallow >5l) bowl.
  • Rags/old newspaper - Because it'll drip and be messy.
  • Philips screw driver - For the air filter housing. Please read the step, I'm hoping somebody will be able to share an easier way than I found.
Materials:
  • New filter - There are two sizes, my handy local spares shop sold me both and refunded the one I didn't need. For the 1.4l petrol I used unipart  UGCGFE585
  • New oil - I think this depends on where you are in the world (temperature) I used 5/40 because it gets chilly here in winter and it's what the book said.
  • New air filter - unipart UGCGFE2570
Step 1Drain the oil
Drain the oil
Old engine oil can be both hazardous to people and to plants so please take care when draining the oil.
NOTE: Oil could be hot if the car has been running recently.
I also remove the filler cap first, I don't know if it helps draining but it makes me happier.
1. The sump drain plug can be reached from the front of the car, I put down some board and newspaper then used a cut down washing up basin to catch the oil. Ordinarily I'd use an old oil bottle with the side cut out, this leaves the screw-able lid as a handy pouring spout.
2. Remove the drain plug, I used a 15/16" socket but the internet says it's actually 22mm. The first photo is a view from the front of the car.
3. Remove the filter (see pictures 2, 3 & 4). It's inside a plastic housing slightly right of middle at the front. The housing needs a 27mm socket.
4. Leave the oil to drain while enjoying a cheery refreshing cup of rosie or changing the air filter.
5. When the oil has drained you can put a little rinse of new oil through if you like that sort of thing. I tend to use the dregs from last years oil change.
6. Seat the new oil filter into the housing, it sits on a peg. The filter housing cap also has the rubber washer replaced. Replace the housing cap.
7. Replace the sump plug, some people use a little lock-tight. Nip up well.
8. Add new oil via the filler cap, it looks to take about 3.5l so add ~3.25l and check the dip stick while adding the rest.
NOTE: The point of filling is close to the exhaust manifold, any oil split on here will smell bad for a good few minutes so make use of your rags to keep potential spills off (or to wipe up).
9. Run the car and recheck the level is good.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:cbm104
