3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Old-World Light Bulb Load
When working with power electronics, quite often the right piece of test equipment is an old-fashioned incandescent lamp. They make good ballast resistors and dummy loads for a variety of devices. A 100W bulb starts at about 10© when cold and works its way up to about 150©, so they even adapt well to a wide range of voltages. Plus, they are cheap, available in a several values, and generally do not explode on failure.
As I have been designing a little power supply myself of late, I decided to make myself a little box to hold a pair of light bulbs wired to standard 5-way binding posts. For some reason, I decided to make something nice, and to try to improve my woodworking skills at the same time.
I am a fan of all things steampunk, and so I decided to try to make something with a similar old-time feel.
Step 1Electrical Parts
Electrical Parts
I started by finding the essential electrical parts. I found the small porcelain light bulb sockets at Home Depot, and I picked up the standard 5-way binding posts from Radio Shack. I have to admit that I was very tempted to use knurled brass thumb nuts instead of modern binding posts, but since this device is also meant to be useful, it has to accept banana jacks, and so I resigned myself to having a little bit of plastic.
My original plan was to simply mount all these parts to a board and get back to work on my power supply. The problem was that the binding posts expect rear connections. The light sockets are more flexible, but they do allow rear wiring.
I quickly came to the conclusion that I would need a box.
28 comments
May 17, 2012. 7:12 AMsilver55 says:
Dexterity 10
Safety 1
There is no protection on the wires to the terminals.
The voltage of 125 V AC is dangerous.
silver55
Jan 10, 2012. 7:19 PMalames says:
If the plastic is objectionable, you might consider old fashioned binding posts. Consider brass posts with horizontal holes, and a nut to bind the wire in the post. I seem to remember seeing some brass binding posts with axial holes that your banana connectors would fit into.
Apr 11, 2011. 7:38 AManvil_man says:
Nice job. Got me thinking ... years ago I was in this old time blacksmith shop and he had this large array of different size bulbs on the wall with switches.
Being young, I had to said what in the world is that for... It was his speed control for his forge blower by turning on different bulbs in series he could change the voltage going the blower motor and the speed..
As I recall this shop was old most likely build before electrical power was common. so when he got power that was a to control his blower..
Mar 21, 2011. 7:41 PMMtalus says:
I use a similar setup for constant(ish) current battery charging. Say 120 watts of lamp to pass 1 amp and then through a bridge rectifier with the output to the battery. Meets all the charging needs that I have. I screw in a plug adapter so that I can plug in a five bulb lamp when I need more current. When I don't need the light I plug in an oil filled motor run capacitor (24uF passes about 1 amp) to lower the waste. Right now I have a 9v alkaline charging with a neon test light as the limit. (I know, I know. Alkalines aren't ment to be recharged. The chemistry is rechargable but the package isn't designed for it. The leakage risk is acceptabel for my Harbour Freight VOM.)
Of course you have to observe voltage precautions and monitor the state of charge. (You make it a "smart(?)" charger.)
By the way, it takes about 3 days for the 9v to charge with the neon limit.
Apr 1, 2009. 7:54 PMfroggyman says:
puting the lights in parrallel should make the lights brighter than is series. just my 2 cents
Apr 1, 2009. 11:48 PMbug on fire says:
and it also makes it look more like something Thomas Edison would make I like it
Oct 6, 2010. 9:40 AMHycro says:
I think clear bulbs might have also been a good choice as well, would give it an "older" look...well, to me anyways...lol.
Oct 6, 2010. 9:37 AMHycro says:
Personally, since I don't have many power tools at my disposal (aside from drills, electric impact gun, angle grinder, and soldering gun) I would have cut with a hacksaw or snips, and rounded the edges either with a file, or the snips again...(whether I use the snips or not really depends on the thickness)
May 2, 2010. 10:21 AMsickdog74 says:
Dang. That's beautiful!
Apr 8, 2009. 1:51 PMCapt. Howdy says:
INSPIRING. Nice joints i havta dust off my delta "thumb remover" and make one of these. i might put a bottom on it rout a couple key holes in it and mount it over my workbench. when not in use for electronics projects it would add some light to my work area.
Apr 9, 2009. 7:26 AMCapt. Howdy says:
some time ago i built a jig for my table saw for cutting that type of joint. i've never lost a thumb to it but i always figured that would be the best tool for the job.
Apr 2, 2009. 12:48 AMRob K says:
What kind of voltages do you run theses on?
Mar 29, 2009. 8:47 PMUncle Kudzu says:
don't know much about electronics, but i think i get the concept and can appreciate that the completed device is a beautiful marriage function and finish. very nice work!
Mar 29, 2009. 3:06 AMw8znx says:
works and cheaper than a variac
Mar 29, 2009. 12:36 AMblugyblug says:
Nice and Clean. This could really come in useful for some people though (not me, im not an electronics guy)
I hope no one starts ranting about how incandescents are bad for the environment...
Not many people on instructables who yell "1st comment!" =D
Mar 29, 2009. 12:59 AMwolf555hound says:
I would think we'd all want incandescent bulbs, seeing as those long tubey ones*im drawing a blank here* have mercury in them. I just cant get my mind off it. The miracle tubey thingy filled with mercury that we're throwing away... I think i ate too much mashed potatoes...(IDK if you'll get this)
Mar 31, 2009. 6:15 AMcd41 says:
:D I just throw the fluorescents away in my garbage, :D But luckily i have only burned out 4 since i started using them, which is weird because it says they should last for 5 years(probably some small print somewhere to mess with that number) and they burned out in 2 months, rip off
Mar 29, 2009. 1:31 AMblugyblug says:
Lol????
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:CaladanJen
Geek of all trades. I love building stuff. Electronics is my passion. Software is my trade. I dabble in several forms of art.
