Olympic weights made from bottles
This is an instructable for how to make a olympic weight. The parts are easily found in the bin.
Step 1Materials
Materials
Materials:
2 - Little bottles;
1 - A piece of PVC pipe with a internal diameter equal or next to the external diameter of the bootle (15 cm);
1 - Ground stone (2 kg);
1 - Some kind of glue;
Tools:
1 - Saw;
1 - Heater (in my case, the stove );
1 - Something with a conical tip;
14 comments
May 25, 2009. 2:24 PMthefoodman says:
(removed by author or community request)
Sep 5, 2010. 11:21 PMbalangaz says:
In the eastern europe, the olympic wl training starts at the age of 9 with acrobatics exercices. There is no maximum weight for a 10 y/o boy, the maximum will increace with training. Also, by the age of 13 (+-), the kid will develope greater mass on the lower part os the body, as for the developement of the upper part goes around the age of 16(+-).
Aug 29, 2009. 7:02 AMXonah says:
Not to much, i would suggest like MAX 5kg (11lbs).
Sep 3, 2008. 8:17 AMDEFDOM DELTA says:
This is excellent! I was curious if you knew approximately what weight these fail? (fall apart?) or if they do?
Aug 24, 2008. 8:06 AMactsofsubterfuge says:
Hah. I thought the bottles were full of croutons at first. Interesting concept. When I was studying abroad and didn't have access to a gym I filled 2 litre bottles with water and strapped them together for some basic lifts. Stone might have been a better choice though. Much heavier than water.
Aug 25, 2008. 9:21 PMLiam Wolf says:
I don't know, don't doubt the heaviness of water.
Aug 21, 2008. 5:48 PMgreatpanda says:
Um, olympic? Great ible for cheap weights, but I think superglue's tensile strength might fail under competition loads...
Aug 25, 2008. 7:46 AMEvilthingamabober says:
SUPERGLUE WILL NEVER FAIL YOU! The bottle might, though...
Aug 15, 2008. 4:22 AMLiam Wolf says:
This is great for people who don't or can't buy weights, or get to a gym for that matter. I have alot of bottles laying around, luckily, so I'll be giving this a go. Thanks.
Mar 10, 2008. 12:55 AMsideways says:
Great idea, and I can add weight later as I get stronger. Thanks for posting this :)
Jan 29, 2008. 5:04 AMUltraMagnus says:
nice, although lead shot would probably work better, but that can be expensive
Jun 25, 2007. 11:09 AMj626no says:
you could also try filling it with cement. my science teacher said that they used to fill old metal acetone cans with concrete and lift them with a steel bar (good cheap and effective). this is a really good idea though, great job.
Jun 25, 2007. 10:59 AMwillofgod says:
You could keep the dirt from shifting by topping off with expanding foam.
Jun 24, 2007. 1:20 PMcry_wolf says:
Wow i'm impressed. Good work on the easy to follow instructable. I'm too cheap to buy my own weight set so this will sub right into my life perfectly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:imgentini
