Yesterday's instructable only supported full press shooting. Version 2 supports both half press and full press shooting modes as well as a BULB switch for timed exposures.
This instructable will build on the previous remote and add the functionality of auto focusing (half press) and shooting from the remote.
I find this to be a great replacement for the $57 Olympus RM-UC1. My total material cost for this project was about $9 (including the disgusting gum). This is a very fine deal.
This should work for the following cameras (thanks Lori!):
E-410, SP-510UZ, SP-550UZ, SP-560UZ, E-410 and E-510
For those unfamiliar with a Remote Cable Release, this device allows a photographer to shoot a picture without directly touching the camera. Using the remote ensures that the camera does not move during the exposure. This is especially useful for taking macro photographs, photographs with long exposure times or photographs in odd positions.
Standard Disclaimer
Your camera is probably pretty nice. You probably spent a lot of cash on it. If you are afraid that you might hurt it and that hurting might make you sad, don't even think about trying this project. I'm not an electronics expert, but I'm fairly certain that none of what I'm about to tell you can possibly hurt you or your camera, but I could be terribly mistaken. This project should leave you with an excellent remote and a satisfying feeling. There is a small possibility however, that following my directions could lead the sun to burn out, your house to fall down or cause your medical insurance rates to go up. Use these instructions at your own risk. Your mileage may vary.
Cheers!
Aaron
Remove these ads by
Signing UpStep 1Gather Your Materials
- A prepared 12 pin remote cable. Follow the Olympus Evolt E510 Remote Cable Release instructions through step 8. Then return to this Instructable to complete the release. Check ebay for cables. I have found that most Olympus cameras use the same 12 pin connector as the Evolt series.
- An enclosure for housing your project such as Herseys Ice Breakers Sours Gum
- Two SPST Momentary push button switches Radio Shack PN 275-1571
- Radio Shack Multi Purpose PC board PN 276-150
- One DPDT slide switch Radio Shack PN 275-403
- Hookup Wire (22 gauge works well)
- 2 6-32 1/4" machine screws and nuts (for securing the switch)
- Small zip tie
- Dremle Tool or similar high speed rotary cutting device with ceramic cutting blade for cutting PC board
- Drill
- Utility knife
- Soldering iron with pencil type tip
- Solder
- Screw drivers
- Needle nose pliers or forceps
- Implements of Destruction (As this was made on Thanksgiving, an Arlo Tribute was necessary.)
- Patience
With this and some other stuff on the Inet I managed to make a triple-way connection for the Olympus E-420 . It works absolutely fine!!!!!
This connection is I think you can get the most out of an E-420 , for the other models I m not sure.
It is USB (Studio 2) / S-video (live view) / and wired Remote control on the same plug.
I can use it now with Studio 2 , external screen (for liveview ) , and wired remote all at the same time , and use all the functions of the camera.
For the 420 I discovered al slightly different pinout ?? the only difference was the video shield also needs to be connected to the shell of the plug.
Thanks!!!!!!!!!!!!
Does anybody know a way of using a PDA with windows mobile for operating a DSLR?
I found this: http://www.astromist.com/palmdslr.html
But that's for a Palm PDA (and some other camera) Too bad I'm not a software engineer.
1. The cable mini-usb to olympus-usb isn't difficult to make.
2. Using a windows-operated pda would be the easiest solution for operating your camera, as a remote release thing and as a remote interval/timer.
But who's going to write the code?
Anyway, keep up the good work!
http://www.txoof.com/2011/04/time-lapse-intervalometers-and-555.html
I ended up removing the focus button and pulling both focus and fire to the same button. I found that most of the time I use this remote, I shoot with the camera on manual focus.
My setup uses exactly the same pin outs as the RM-UC1, it just isn't as pretty.
Let me know if it does work so I can include that in the instructable. Thanks!
You can check out the Oly remote here: http://www.olympusamerica.com/cpg_section/cpg_support_accessories.asp?id=1294&ct=48
SystemChart_E-500_300
Fourthirdsphoto_Forum
I should have bought a narrower box but its no big deal.
It works and it works well....
http://www.maplin.co.uk/module.aspx?ModuleNo=43710&doy=25m1
Cracking little mod....
