3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Olympus Evolt E510 Remote Cable Release (Version 2 with Auto Focus on Remote)
Step 3Prepare the Enclosure Part I
Cut a hole 11mm long and 7mm tall on the hinge side of the enclosure using a utility knife or Xacto. Locate the hole about 15-16mm from the corner of the box and no more than 5mm from the hinge. Be sure that your switch will have a flat surface to mount to; the curve in the corner of the box will interfere with mounting if the hole is cut too close to the corner.
When cutting the hole, first draw out the shape and size needed with a marker. Then begin cutting by very carefully scoring the exact length of each line. Repeat this process, cutting slightly deeper each time. With patience it is possible to cut a very precise opening.
Insert the switch into the opening and mark the holes for the mounting screws. Drill the holes. Use the utility knife to enlarge the holes as necessary.
Measure the diameter of the cable. Drill a hole of slightly larger diameter in the edge of the enclosure to accommodate the cable. Locate this hole in any edge that will make holding the remote comfortable.
TIP!
For a better look, cut the holes from the INSIDE; this will help hide any accidental slips with the utility knife.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:txoof
