3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Olympus Evolt E510 Remote Cable Release (Version 2 with Auto Focus on Remote)
Step 4Prepare the PC Board
Thread the camera cable through the opening created in step 3 before you being soldering.
If necessary, cut the wires for the DPDT switch so that they are a convenient length for the enclosure. Leave some slack to allow easy installation of the switch later.
Solder the components to the PC board using the schematic provided.
  • SW1 - DPDT slide switch
  • SW2, SW3 - SPST
Test your circuit using a multi meter. Once you are satisfied with the results, plug the cable into your camera and test it.
  • DPDT switch should result in a full button push - the camera should focus and release the shutter immediately.
  • SW2 should wake the camera from lite-sleep (monitor off) but do nothing else on its own
  • SW3 should auto focus and meter
  • SW3 and SW2 pressed together should result in focus and shutter release. Press SW3 to focus and then SW2 to release shutter when ready.
Cut the used portion of the PC board free using the Dremel tool.
TIP!
If you are unfamiliar with electronic schematics, the circles on the left side of the diagram indicate the connections to the cable for pins 3 and 11. The circles on the right side with a "-" next to them indicate ground. solid boxes on lines indicate connections between wires. Crossed lines do not connect unless there is a box over them.
Note, The schematic below is mislabeled; pin 4 should ACTUALLY be pin 3. Thanks to everyone that pointed this out!
10 comments
Jan 19, 2008. 1:18 PMcornz says:
Fantastic little hack..Just made mine and set it up as i wanted it. Only other thing i might do is get some white letraset and label the switches. Well done for posting this.Ssaved us Oly users a small fortune.
Jan 25, 2008. 11:13 AMcornz says:
It was a small project box from "maplins".
I should have bought a narrower box but its no big deal.
It works and it works well....
http://www.maplin.co.uk/module.aspx?ModuleNo=43710&doy=25m1
Cracking little mod....
Jan 19, 2008. 1:21 PMcornz says:
Completed remote shutter..
Jan 2, 2008. 10:09 AMLori C says:
Great project. Should the last sentence of the 'Test your circuit...' be amended to : 'Press SW3 to focus and then SW2 to release shutter when ready.'
Jan 9, 2008. 11:54 AMLori C says:
It took a while but I finished the project and it works just great. I found a number of suitable containers in the electrical dept. of the local thrift store. Small transformers that can be opened ( some are sealed and not screwed together), game consoles, etc. I used a 'Mad Catz' (whatever that is) for my remote. One additional diagram (attached) that could be given is a pin numbers one of the rear of the Olympus connector in relation to the front pins. Many thanks, Lori
Jan 9, 2008. 5:41 PMLori C says:
To remove the boot on the Olympus video cable I placed it in boiling water for a minute or so and it was easy to slide off. I did not even bother to de-solder the two video pins - I just gripped the wires and pulled them out. The two missing pins make no difference to the remote operation as pins 5 and 9 are not required. The video cable was discarded and two wires and the ground in an ordinary USB cable, which I purchased for $3 at a thrift store, was used. Soldering the wires to the connector was done very slowly and carefully. I did not use Gorilla glue (I didn't have any on hand) but used a glue gun for insulation purposes and then heated and replaced the connector boot anchoring it also with the glue gun.
Jan 9, 2008. 12:10 PMLori C says:
I forgot to mention I use an E-410 but the Olympus version (RM-UC1) also works for the following cameras : SP-510UZ, SP-550UZ, SP-560UZ, E-410 and E-510. I don't know about the E-500. Lori
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:txoof
