On-Board Air Compressor / Welder for vehicles
When we go to help on a project we usually only take out battery powered or hand tool. We have to leave our pneumatic tools at home, with a on-board air compressor we dont need to leave our pneumatic tools in the shop anymore.
Step 1To start off - Why do I need a air compressor?
Why do you need a air compressor on your car or truck? There are a few answers.
You can:
1. pump up a tire
2. change a tire(with a impact wrench)
3. inflate you favorite water toy
4. paint a car (with a paint sprayer)
5. put on a roof(with a nail gun)
6. power a spud gun
7. Make: something
8. Because its cool
I could make this list go on for a while. Anything you use your shop air compressor for you can use this on-board air compressor for.
You will probably find a use for it you never thought you could use a air compressor for! I know I did. (supercharged a charcoal grill)
21 comments
Sep 9, 2011. 4:04 PMKaljakaaleppi says:
I like this. I have an old Mercedes which does not have AC. I can stop dreaming about instaling AC to that one (a huge project, btw) and use the slot as a air compressor! Just finished building a stick welder from old microwave transformers, so a car welder would be the next logical project :).
All this, after the WVO-conversion is finished, that is... :/
Jun 23, 2011. 11:04 AMbkatt says:
Instead of dealing with the oiling situation, couldn't it be easier to get a air pump from a 110V air compressor? Granted you don't have the electric clutch, but I'm sure something else could be fashioned...
Jul 1, 2011. 6:31 AMHolder350 says:
The oil-less 110v compressors are crappy and do not put out much air.
The oiled 110v compressors must be kept upright when running to insure proper lubrication.
Basically an A/C compressor is the best bet over finding an actual OBA compressor.
Jun 23, 2011. 11:10 AMbkatt says:
Instead of idling up, wouldn't it be better to change the pulley sizes somewhat to doubt the RPM the welding alternator sees?
Also, can the welding alternator and/or air pump be setup to run in reverse? I am considering this modification for my fullsize Caprice wagon. It doesn't have a lot of room left alongside the engine, as I wish to retain my A/C, but I do have space in front of the engine, if the units could be flipped over and spun backwards.
Jun 20, 2011. 7:01 AMmntbkrguy says:
Very well explained! I have seen many threads on different offroad forums but yours has much better detail and answers a lot of questions.
Jan 6, 2011. 8:24 PMfreddyg3753 says:
is the 30 amp switch grounded or does it have + power from the battery?
Dec 26, 2010. 5:32 PMbakermonitor says:
So this removes your ac, could it be done with out doing that?
Aug 29, 2010. 8:03 AMBosun Rick says:
Do you have any info on using late model Mopar alternators?
Jul 7, 2010. 6:22 PMspa31rky says:
I have seen this before and also helped a friend do this back in early 80's........works great too
Jun 21, 2010. 7:01 PM2 stroke says:
i dont even have a air compressor a t home lol but i have a stick welder
Feb 25, 2010. 6:00 AMRahdzhillaxxx says:
When  build my  "train hor" I'll certainly keep this  'ible in mind :)
Aug 22, 2009. 8:07 AMrbodell says:
Nothing like everything being in reach on the workbench LOL
Jul 4, 2009. 10:03 PMabadfart says:
nice ill half to try this with my work truck
Mar 29, 2009. 1:08 AMtowtruckr444 says:
now on that they have electric solenoids that can idle up an engine when current passes. you may look into that for the air compressor wire or when the alternator senses current flow. they are adjustable too. I'll look into that.
Feb 5, 2009. 8:38 AMarriero4x4 says:
I'm installing a York 210 compressor, and i'll check around for materials to build your welder. Thanks a lot for this instructable. Arriero Chile
Jan 29, 2009. 9:25 PMskunkbait says:
This is AWESOME! I've got a couple of old work/hunting trucks that need something like this. I think this'll be one of my first spring projects.
Jan 5, 2009. 8:29 PMLinuxH4x0r says:
Got my vote!
Jan 5, 2009. 4:49 AMstephenniall says:
I can remember when i finished my 'bike air horn ' i had a short burst compressor on it and i put a 'Push to make ' switch and filled the pipe up with BBS It was pretty funny and ran off a small battery i have
Jan 4, 2009. 8:20 PMkillerjackalope says:
If you're ever looking for a heavier duty compressor setup in vehicle you could always run a direct drive one from a PTO alternatively we used the gearbox on our old iveco to run the crane, a hydraulic motor isn't hard to get a hold of, the downside is the engine needs to be at high revs for lots of power or it'll stall out, however it's a more useful power source than the electrical system if it's heavy usage... Interesting combination of tools though, you'd have pretty much everything covered. For less confident people or those that don't like the idea of putting a welder together you get a unit built for landrovers that might be of use, I've seen the fitted to various jeeps and they're a fully fledged powerful welder... Some more photos would be nice though...
Jan 4, 2009. 8:57 PMkillerjackalope says:
Ah right, fair does, those welders do come very cheap second hand, it was more a suggestion for people that weren't comfortable with making their own, or for working environments, if other people are using it they can be health and safety issues with homemade machinery, even if it's perfectly safe...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:DeathBlade
