Step 15The cables
The Welding cables you use should be at least 4 gauge wire, to handle the voltage and amperage going through them, My cables are 20 feet long if you go longer consider going to a larger cable to keep the cables from over heating.
Your stinger or rodholder should be rated for atleast 200amps. The ground clamp should have good spring tension for ensure a good ground. You can pick up either of these at you local welding shop, Sears, or Harbor Freight
One of the things people try to skimp on is your welding helmet or hood, Buy a descent brand name one if your first learning to weld go for a auto darkening it will make things easier.
Add Comment
