3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Basics of Beginning of the Top Secret Bunker Project and Removing Soils
I've been pondering a second house under the one I just finished building bunker style for tornados and just because it would be fun.
A big part of the labor involves moving the sand and clay from under the house to the backyard and if you've ever watched Escape from Stollagg 17 and really thought about the dirt in the socks trick, a Yard of Sand is a Lotta Socks...
I started with a crawl space under about half the main floor of the house, and about 4 foot of head room, and a 3 by 4 foot doorway halfway up the steps or four feet above the bottom garage floor.
Pyramids have always fascinated me, the shear tonnage of them and I always wonder what they are resting on, the backgrounds always seem to be sand that can flow over time and they have stood for so long a simple shape transferring energy over a large base and when I was thinking of the bunker Idea realizing in Florida at some point I was going to dig into a water table and a heavy pier might over time sink like the Kansai Airport, KIX not being built by kids and needing hydraulics and such to keep it sitting level I thought that an inverted pyramid would be less likely to sink since to go down you'd need to also push some vector off in a horizontal type way and then I thought some more and having been hit in the head but not necessarily made foolish I guestimated 2 feet as about the maximum cliff you could dig into a seam of sand and have it expect to stay put as long as the sand was kept damp and if it collapsed it would probably go to a 45 or so meaning if I stayed more than two foot plus a fudge factor away from anything that might be adversely effected by having it's legs pulled out from under it, in the most broad sense of the term it should be fairly safe...
I added 2 and 2 and a few more and decided the simplest thing to do would be to dig down two feet, form a temporary wall about 4 inches thick, drive some rebar a few feet into the ground and tie them to some running horizontally inside the pour, carry in a few hundred 80 pound sacks of concrete mix, pour the wall, telescope in and repeat the process a few time digging down to pull the rebar from the first pour at and angle and tying it into the rebar for the next one and then when it was 4 or 6 or however many feet high depending on the load next to it I'd form one more wall and end up with vertical smooth walls that are thicker on top than they are at the bottom just like an upside down pyramid.
The deeper I go the less floor space I have but it seemed doable and since I watched the well be put in and dug the very large hole seven years ago into the hill so I could have a level mostly below ground for hurricanes and such, this being Florida after all and things happen, I had an idea of what type of soil was down there, and new there was a seam of clay that was fairly thick and guess that since the lake is about ten feet below the height of the bottom garage I probably could come close to being able to dig down at least one story without it turning into a sinkhole but I also new it would be unwise to just start building something without first taking a look at what was really down there so I decided on a test shaft to test construction methods and get soil samples at certain depths and most importantly how deep you can dig without hitting water since dampness and closed up places don't go well together and an ideal emergency shelter is ready at a moments notice even if it has not been maintained for a decade.
At least I think so since I have seen many 1950's era bunkers built for the cold war that are now long flooded because it costs money to run a sump pump.
Fort Walton Beach is full of them if you look hard...
Step 1Walk Like an Egyption
Being not Lazy but hopefully practical I realized there wasn't much fun in working in a four foot crawlspace hunched over and for the time being the only way in and out for anything was the door way halfway up the stairs, I figured it best to start near the opening to save the distance I had to shovel but not so near that you'd need a ladder to crawl down under the house if a pipe broke or something and compromised by first digging down 2 feet below the opening which let me stand up as soon as I got under there and then dug to the left of that and cleared a ten by ten floor area for the test shaft.
This was just sand but under normal situations the crawl space stays very dry which is more dumb luck than anything so I would need to spray it with the hose a bit to soften it up since there is a small amount of clay in it as well.
I started by cutting a sheet of plywood wide enough to fit over the steps forming a ramp between to block walls filled with concrete once again having spent many moments pondering the building of Pyramids it's entirely possible I meant to do this when I first laid the blocks for the bottom level just like how the supporting columns in there holding a beam so I can have 20 foot spans above are spaced so you could knock a hole in the back wall of the bottom garage in an area that just happens to not have rebar like it was meant to be sawn open with a partner saw and then drive a BobCat under there and go to town but that would imply long term planning and possibly lead to a much longer post than intended but it was pretty simple to shovel sand out the opening then when I got a big pile shovel it into wheel barrows and use it to fill in lowspots in the yard.
And it was good exercise!
34 comments
May 3, 2008. 2:37 AMRishnai says:
Brother mole! I can totally see myself doing a dig like this the instant I get a house with an unfinished basement. My neighbors would just see a growing pile of dirt, and the fellow across the street crawling under his house all weekend, every weekend.
May 3, 2008. 9:27 PMRishnai says:
Mwahahahaha! They shall never know about the bunker! Sneaky, and useful.
Oct 19, 2010. 5:41 PMgurgle528 says:
unless your wife goes on instructables lol
Sep 11, 2009. 6:00 AMcowscankill says:
Very incredible! I have always wanted to something like this, but in my stupidity I might make the house cave in when digging under it. Is there any other good places to put a hidden bunker?
Sep 25, 2010. 7:08 PMHightechk says:
why not in your back yard
Sep 26, 2010. 12:37 PMHightechk says:
ah good point
Feb 13, 2010. 3:05 AMnutsandbolts_64 says:
I can imagine myself digging a post-apocalyptic bunker while I reinforce my fortress house with sandbags!
Jun 15, 2009. 2:39 PMabadfart says:
nice now i can hide from the government and storms
May 7, 2009. 2:50 PMbart10655 says:
I am making one kinda like this i will post my progress as i do it. It might take me a year or so tho.
Feb 9, 2009. 11:56 AMGEAR says:
Ya, I know I am a little bit beind the times but I just came across this hole of yours so I have to say... Hats off to you, Your hole looks very nice and well done. I dug a hole in the back yard that I will have to send you a picture off, just because I am at work now and my pictures are at home. Hats off to all who dig holes.
Feb 11, 2009. 5:01 PMGEAR says:
Good man you have a couple of years on me then. My first real digging adventure was when I was in grade 1 and I started undermining the bus stop shelter. A couple of weeks later it fell into the ditch, ooops. At any rate I shall subscribe so I can keep track of your digging, and I will post a picture of my hole one of these days. later,
Sep 8, 2008. 11:19 AMirritant#9 says:
Interesting instructable. Could you add comments to your pictures? Also a few periods would be cool.
Dec 16, 2008. 7:34 PMHollon says:
I was thinking the same thing as irritant. Haha, you do realize "The deeper I go the less floor space I have but it seemed doable and since I watched the well be put in and dug the very large hole seven years ago into the hill so I could have a level mostly below ground for hurricanes and such, this being Florida after all and things happen, I had an idea of what type of soil was down there, and new there was a seam of clay that was fairly thick and guess that since the lake is about ten feet below the height of the bottom garage I probably could come close to being able to dig down at least one story without it turning into a sinkhole but I also new it would be unwise to just start building something without first taking a look at what was really down there so I decided on a test shaft to test construction methods and get soil samples at certain depths and most importantly how deep you can dig without hitting water since dampness and closed up places don't go well together and an ideal emergency shelter is ready at a moments notice even if it has not been maintained for a decade." is only one sentence?
Oct 11, 2008. 6:14 PMSolderguy says:
About how much would a project like this set you back?
Jun 2, 2008. 4:16 PMdarkmuskrat says:
The easiest(not quite legal) way to do this is just to insert a 1 1/2 inch(or more...more would be better) plywood box with reinforcements the size of said bunker under the ground where you want it when your building your house, dig a hole(you should have all the machines there. then dig it up later through your basement XP
Apr 22, 2008. 12:26 PMtoastyboy says:
This is very very VERY cool! I can't begin to tell you the times, I've talked through the idea of building a bunker with my friends and wife, and then have never done it. I would just LOVE a bunker like yours, I always wanted an 8' cube bunker in the garden, ideally with access through the garage floor. Thanks for the detailed explanation, I've really enjoyed reading it. all the best -Dan
Apr 21, 2008. 3:42 PMMr. Rig It says:
Great Job Senseless Very cool. Please feel free to add any and all of your home improvement projects to my group. I know you have added one, but it would be great if you added your other as well. Here is my group Home Repair, Refurbishment, and Projects and great job!
Mar 31, 2008. 2:34 AMgmjhowe says:
wow, nice job mate!
Apr 1, 2008. 2:58 AMgmjhowe says:
Your a pro - keep up the good work! Extremley high quality - but then it could just be that it all looks so complicated to me!
Apr 3, 2008. 4:45 AMgmjhowe says:
yes, my friend, that myth is truth. Its not that u made them more complicated, its just im a graphic designer - different proffession - therfore different knowledge!
Apr 4, 2008. 3:03 AMgmjhowe says:
Looking at the site, i must say its not that bad, nice and simple, well laid out. i have seen far far worse.
Apr 1, 2008. 9:04 PMjehan says:
i am in the process of building a bunker in my back yard but its much harder since it all clay and i am hand digging it. i cant find a easy way of removing it without a lot of work.
Apr 2, 2008. 7:49 PMjehan says:
yea i live in the city so i cant use the water. i have been piling the clay around the sides of the hole so it is deeper. i really wish i could get a backhoe but i cant get one to were i am digging it. i didn't pick a very good place since it is behind my shed so i cant get any big equipment behind it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:Senseless
http://senseless.livejournal.com/ I've been attempting to build a house mostly by myself for the last five years... I finally more or less finished it before the bunker project and after recover...
more »
