Introduction: One Step Trick - the Tilde Button in Illustrator CS and Above
Picture of One Step Trick - the Tilde Button in Illustrator CS and Above
This cool trick will blow your mind, because not only is the outcome truly awesome, sketchy and abstract equally but also very easy to achieve.
You can make great wallpapers, backgrounds and textures with simple and a ONE KEYBOARD BUTTON trick!
Step 1: There's Only One Step! Literally!
Picture of  There's Only One Step! Literally!
All you do is to select a shape or a type of line from the shape tool or line tool, respectively, located in the tool bar. Then before making the shape on to your document, you press the TILDE (~) button on your keyboard and keep it pressed. Now draw your shape on the document and move your cursor in different directions. See what happens!
Things to note:
1) Make sure your fill is set to none and your outline or stroke of the shape or line is colored.
2) You can only use this trick with the shapes and lines available in the tool bar
Just choose all the different shapes and lines available to you and experiment with this amazing technique!
I will be starting my blog soon and give you the link. It will have more detailed tutorials and different ways to use such techniques.
livichris (author)2015-03-08
MS Word?
AaminaS (author)livichris2015-03-08
Oops I am very sorry, I forgot to mention the program in this one. This is Adobe Illustrator trick.
LydiaT2 (author)2015-03-08
What program are you using? I don't understand what you are talking about. This doesn't make sense at all. Please explain better.
AaminaS (author)LydiaT22015-03-08
petercd (author)2015-03-08
Does nothing in MS Paint, which program is it?
AaminaS (author)petercd2015-03-08
AaminaS (author)2015-03-08
About This Instructable
803views
19favorites
More by AaminaS:The Width Tool is Fun - illustrator CS 6Make Your Life Easy - Useful Illustrator shortcuts!!One Step Trick - The Tilde Button in illustrator CS and above
Add instructable to:
