One sheet Plywood Bench
 by Brown6041
Contest WinnerFeatured
This is a cheap way to take 1 sheet of plywood( this one is 1/2" thick) some bottles of gorilla wood glue and a few power tools and
make a cool unique laminated bench.
This is my first instructable so i hope it is up to par, but if not i will work on my technique for the next one.
Might i add the only fasteners used in this project is glue and some wood pegs THAT'S IT.
Well lets get to it.
Step 1: Tools needed/layout
tools you will need:
Table saw or skill saw
tape measure
clamps
speed square
pencil
drill
  7/8" forsner or spade bit
I think that is all but i will check as this process goes.
Layout:
For this project your biggest tool is your mind. Take some time to sit down and figure what size you will have to cut everything.
For this particular bench I took a standard sheet of 1/2" plywood and cut it in to 1.75" x 48" strips. The thicker the plywood the wider the strips can be.
You can vary the size based on the width and height of the bench you want to make. Today i will cut portions down to make a bench roughly 36" long by 18" high. On to the hard work
rpjamess1 says: Feb 24, 2012. 6:24 AM
A trick to use to prevent the laminate boards from bending at all is to alternate the clamps on top and bottom. This provides an even pressure on both sides of the laminate.
Yerboogieman says: Oct 16, 2011. 7:50 PM
I have a planer, they are a great addition to any workshop, and much faster than a hand-planer.
shuja.shaher says: Oct 11, 2011. 8:22 AM
that means i am sure to go with the design thanks
Brown6041 (author) in reply to shuja.shaherOct 11, 2011. 11:17 AM
if you want extra security just use longer dowels too.
shuja.shaher in reply to Brown6041Oct 12, 2011. 6:53 AM
THANK YOU ONCE AGAIN
shuja.shaher says: Oct 10, 2011. 7:01 AM
great design
a doubt as usual
are the dowels holding?
Brown6041 (author) in reply to shuja.shaherOct 10, 2011. 3:39 PM
been a year lots of jumping on it from kids and fat people and hasnt moved at all.!!
MCUman says: Oct 9, 2011. 6:10 AM
This is Great project. I would make the following suggestions, though. One good side landing by someone of substance could collapse the legs too easily. May I suggest moving the legs in by 2", cutting a 1/2" deep mortise for them, fill the groove with glue and hold them in place with 3/8"X 6" lag screws with fender washers under the heads in place of the wooden dowels. Place a 2X4 centered between the legs, running the length of the bench to farther reduce sideloading movement and increase strength.
Brown6041 (author) in reply to MCUmanOct 9, 2011. 6:34 AM
you would think it would collapse easy but my dad is 260 and has dropped down on it hard before and nothing it is surprisingly stable those pegs can go as far in as you need and they are hardwood, so not likely to break. the goal was to keep it as simple and sleek as possible but thanks for the advise
Dshach says: Oct 8, 2011. 8:04 AM
Very nice work!
Tried to figure out what is the missing measure: hight 18", width 36", but what is the depth of the bench? I counted 25 pieces in the photos, which makes total of 12.5". Am I right?
Brown6041 (author) in reply to DshachOct 8, 2011. 12:12 PM
yep right around 12.5
leeski says: Oct 7, 2011. 3:45 PM
great looking project. It was just picked up by apartment therapy. com
congrats.
http://www.apartmenttherapy.com/chicago/woodworking/make-a-modern-bench-from-a-single-sheet-of-plywood-instructables-157916
mrserious says: Oct 6, 2011. 3:49 PM
Looks very nice. I am considering doing a similar design for a fireplace mantle front. One thing you may want to consider is to miter the ends of both your bench top and legs, which would minimize the glue line and continue the lines from the plywood lamination along its entire run.
Beauceron says: Oct 3, 2011. 6:02 PM
Not bad for plywood!
smschaff in reply to BeauceronOct 6, 2011. 9:03 AM
Should use CDX Plywood rated for exterior use.
stoobers in reply to smschaffOct 6, 2011. 2:34 PM
CDX is "rated" exterior, but that is only as it applies if it gets incidentally wet during construction. In other words, after and certain number of wet/dry cycles, it falls apart, so you better finish your house before that point.
ADX, BDX, CDX, wafer board - they all fall apart the same way.
Brown6041 (author) in reply to BeauceronOct 3, 2011. 6:11 PM
thanks a bunch, just had to see beyond the plain ole plywood and see what was there. by the way everyone feel free to vote in the make it stick 2
andygreene says: Oct 4, 2011. 11:45 AM
Cool design and execution. A variation might be to cut half of the strips for the top 3.5" shorter, and half for the legs 1.75 " shorter, then assemble them layering it from the edge. your joint would look like fingers interlaced....
you might need a jig to keep the angles at 90...
Questor in reply to andygreeneOct 6, 2011. 12:45 PM
don't need to cut them, just stack every other on out the width of the strips.
jbrecken in reply to andygreeneOct 4, 2011. 9:44 PM
You'd also need more clamps, since you'd want to laminate the legs and the top together at the same time. Trying to assemble the finger joint after the glue has cured on the three separate pieces would be difficult and likely to chip the plywood.
Brown6041 (author) in reply to jbreckenOct 5, 2011. 5:55 AM
i may give this a shot with some left over pieces i have to see how it looks/works
Brown6041 (author) in reply to andygreeneOct 4, 2011. 4:28 PM
that is very weird because i was literally just thinking about that crazy.
Questor says: Oct 6, 2011. 12:43 PM
if you stack the strips so that every other one sticks out the with of the strips then glue them you could make a finger joint where the legs meet the bench.
mahvin says: Oct 6, 2011. 11:22 AM
Just make a centering jig from a thin sheet of masonite cut the same size as your vertical end, lay it on the top bench edges and mark your drill points.
technofossil says: Oct 6, 2011. 10:53 AM
Nice project and good illustrations.
You fail to mention how you line the legs with the top so the dowels will fit correctly. Since the legs are the same width as the top, there is no room for error. How did you do it?
Brown6041 (author) in reply to technofossilOct 6, 2011. 11:16 AM
you just have to make sure you measure twice or three times and give yourself a good layout. like they say preparation is 90% of the battle
mikeasaurus says: Oct 6, 2011. 9:04 AM
Looks great, I love the texture of the stacked wood grain and the finish really makes it pop!
papalindsey says: Oct 6, 2011. 8:56 AM
I think this thing is absolutely awesome! Great job.
Comanchegyrl says: Oct 6, 2011. 6:59 AM
This looks good and turned out better than I would expect with that saw. Congratulations. You could make it a bit stronger by cutting your lengths first, cutting half the full length and half shorter by the width of each ply. When you alternated the glue-up, you could have a finger-joint (simplified dovetail) which could be glued and pinned through the ends.
nathanrudolf in reply to ComanchegyrlOct 6, 2011. 8:10 AM
A bit more work, but a great improvement. It would be stronger and eliminate the need of dowels, along with making it slightly more elegant.
Brown6041 (author) says: Oct 6, 2011. 8:09 AM
i want to thank everyone who has looked at my project and for all those you will come in the future. Also thanks a bunch for all the great ideas to make it better, will try these out in the future. If everyone could make sure you VOTE for the make it stick 2 contest. Thanks again
jeffeb3 says: Oct 3, 2011. 12:38 PM
You definitely made the right decision sealing this. Generic plywood expands when it gets wet. The glue will help, but I bet a single rain storm, or a spilled soda on an unfinished bench would ruin it.
Brown6041 (author) in reply to jeffeb3Oct 3, 2011. 3:49 PM
i totally agree. Thats why i sealed it. The one at my parents stays outside and hasn't changed in over a year.
l8nite says: Oct 2, 2011. 10:03 PM
great table and a very well done "ible" thank you for sharing
JackME says: Oct 1, 2011. 5:19 AM
A very good 'ible, looks like a very good project! Now i only need a garden i have an excuse to build one! ha
Brown6041 (author) says: Sep 30, 2011. 4:41 PM
built one for my parents and they keep there's outside looks great in nature.
Flintlock says: Sep 30, 2011. 4:27 PM
Fantastic! Would look great on the deck I'm trying to decorate!
Brown6041 (author) says: Sep 30, 2011. 1:20 PM
to be honest i just grabbed a sheet of plywood that looked good but i would say glue an wood ranged from 30 to 40 dollars.
and for step 5 i have an electric hand planer, used it to get close then sanded the rest as smooth as i could.
Thanks for the positive feedback
h3idi says: Sep 30, 2011. 12:48 PM
I think it's beautiful, thanks for showing us that. :)
etlerd says: Sep 30, 2011. 12:15 PM
Looks nice. Some questions:
1. What kind of plywood did you use? There are many 'standard' types, and it's interesting to know what you chose.
2. How much did your materials cost? Ballpark is fine, since wood costs vary by region anyway.
3. In step 5, which method did you choose to smooth the top? I once did a similar project gluing strips of plywood together to form a larger surface with the end grain as the surface, and the sanding method can be horrible. Ultimately I chose a slightly rough look :)
Brown6041 (author) says: Sep 30, 2011. 12:14 PM
let me know what yall think. Thanks alot for looking.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
