3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
One time use screen printing. (Ghetto screen printing)
Step 3You're pretty much finished.
You\
After you squeegee your ink, take off the screen and go wash it. The last thing you want is a screen ruined from ink drying up.
You can wait a few minutes for the ink to dry, and then peel off ALL of the contact paper.
You'll be left with a perfect representation of what you drew or copied and printed.
After the ink dries, put a sheet of news paper over the shirt and iron it for about 5 minutes, then flip the shirt inside out and iron the back.
If you used tulip slick paints instead, you don't have to iron it. Just let it dry.
So that's the end. You're finished. You now know the ancient art of ghetto screen printing and optimizing the "more bang for your buck" policy.
3 comments
May 27, 2009. 8:09 PMbergiemoore says:
I wonder if you stuck your contact paper to a screen or sheer fabric, and then duct taped it to a frame, if you couldn't get several inks from it? I like your contact paper idea because it's cheaper and more accessible to me then buying a heat gun and begging for sign vinyl.
Mar 7, 2010. 11:55 AMjohnny3h says:
The screen cloth HAS to be strecthed tightly on the frame to prevent "creeping" [shift of the "open" / printing area] of the stencil pattern while pulling the squeegee [to press the ink through the screen].
You will have great difficulty preventing "wrinkles" in the screen cloth in attempting to apply your stencil to loose screen material.  Also...
IF you ty to tightly enough stretch the screen [with the already applied stencil] to apply it to a frame, then more than likely there will be lots of cracking and/or tearing of your stencil which will result in ink getting through the cracxks and ruining your printed image.
Therefore, the screen should be applied/stretched to a frame BEFORE application of a stecil, ensuring the best chance of a quality print representing the master you used to make the stencil.
Aug 3, 2009. 2:01 AMSugarjustsugar says:
I was thinking about trying this(1st timer). what's the best type of ink to use? Is there anything that would give it a shiny vinyl look?
Mar 27, 2008. 10:32 AMgellerja76 says:
Try applyling the contact paper directly to the screen(just remember to flip your image). This way you can do many prints of the same design. When you're done peel off the contact paper and wash your screen. Make sure you clean it right away and you should be able to use the same screen many times.
May 21, 2008. 7:37 AMlotusduck says:
If you draw your design on the backing of the contact paper before you cut it out, you don't need to reverse your image. But this is exactly what I thought this instructable would be. The writer should amend it to imply the same. Also, instead of contact paper, vinyl stickers work too.
May 21, 2008. 11:13 PMqwerty90210 says:
for his use freezer peper would be best, just iron it on
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:gregdoom
I eat too many chicken nuggets.
