3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Only one RCA TV input? No problem.
My TV only has one RCA input, but I have 4 devices that use RCA.  I didn't want to buy parts to build a switch box or buy one, so I came up with this.  It is a really easy project to do, it was free for me because I had the spare parts laying around, and it took me about 20 minutes.
NOTE:  Turning on more than one device at a time might cause problems, I'm not responsible if anything gets ruined.  I doubt it would cause problems, but I wouldn't try it.
Step 1Materials
Materials
-Spare RCA cables
-wire cutters/ wire strippers
-electrical tape
6 comments
Sep 25, 2011. 7:00 AMmgalyean says:
You are 100% correct in telling people to not turn on more than one device as who knows what that could do to any of the devices attached.
There are switch boxes for a few bucks that only allow one device to be connected at a time. More expensive ones have a remote, but when you think about it, having to get up to turn the switch isn't such a bad thing when one has been sitting on one's butt all day playing COD anyway. Getting up to flip the switch might be the only thing keeping one's feet from atrophying and allow blood flow to return to one's buttocks.
Be that as it may, one approach I've thought of for full automation is to have a relay (or transistor/switch) on each output before the TV input. The relays/switches would be configured to allow signal through by default, but cut it off if any other output has signal. Use a high-impedance rectifier on each console output to detect when video signal was present. If so, this would dis-engage all the other relays except the one with signal. If more than one output has video, it they would disengage each other's relay so neither would get through. So if you have no video, it would probably mean you have more than one console turned on.
If this sounds like an interesting instructable I'd be happy to assist someone with design/construction issues if they took it on but unfortunately can't take it on myself at this time.
Jun 6, 2010. 1:32 AMcraig3 says:
you didnt cut the connectors straight from the consoles did you?
Jun 6, 2010. 5:06 AMcraig3 says:
ah alright cool, i was worried a bit that if you cut up the cables straight from the source, then if you ever needed to you wouldn't be able to plug it into a different tv
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:musick_08
