loading
This is not my idea, its been floating around the internet for a while. Its a simple and cheap way to make a padlock shim out of a can of soda or any thin metal.
Step 1: Parts
The only real parts you need for this are a can and a pair of scissors or a razor. If for some reason you dont have a can you can use any metal of the same thickness or slightly thicker.
Step 2: Prepare the Metal
Using the scissors, cut off the top and bottom of the can. Then make one long cut down the side of the can to get a sheet of metal. Then flatten out the sheet, and cut off the jagged sides of it, so you end up with a smooth rectangular sheet of metal.
Step 3: Make the Marks and Cut
The instructions I read for this say to use a strip 1" x 3", however I found it easier to use a slightly more squarish piece works better, so use something about 1 1/4" x 2 1/2". Mark out the rectangles onto the sheet of metal using a sharpie, and then cut them out.
On the smaller rectangles, mark off fourths both vertically and horozintally.
Step 4: Mark the M
Draw a M shape on the rectangle. The M should start out 1/4 in from the left, and shoud be 1/2 up from the bottom, it should curve down so the bottom part is 1/2 in from the left, it should be mirrored on the other side. Its kinda confusing so just look at the photos. After you draw it, cut it out.
Step 5: Folding and Shaping
Fold the top 1/4th down, then fold the 2 side parts up and over. After you finish folding wrap it around a bic pen or some round object, roughly the same diameter as the bar on the padlock.
Step 6: Using
The best method to open it is to have the part of the shim that will go inside the lock on the outside of the bar. Push it down into the padlock, and then twist to unlock it. It can be very hard to master, dont give up. It will probably take a few minutes to get it to work. These are only good for a few uses, because they begin to crumple up and will no longer fit in the lock. A good practice technique is to use an open lock, look inside at the part you are trying to force open, and try moving it while the lock is open to see what you need to do when it is closed.
Quick and easy. Thanks for the instructable!
speaking of burglary tools. when I was younger I used a hammer and screwdriver and screw to break into drink machines...not smart and only did once but I got caught. I was charged with a class 5 felony because I had used burglary tools. I ended up pleading down to petty larceny so I didn't have a felony. moral of story...it can always be worse than you think so if you aren't breaking into your own locked thing don't make the tool. some people like me learn but others dont
Aluminum is too weak. I created this set in 1985 from a brass alloy which acts as a lubricant and is verry strong. The more you use them, the smoother they get. See my webpage concerning brass.. padlockjimmy.blogspot.com
<p>Unable to get the info you promise on your blog, a bit sad I am</p>
+1 As much as I love Arizona Ice Tea, I have to agree.
<p>My first ever lock shim tool. I have to ask a question. I will ask it privately.</p><p>I love this tutorial</p>
A flat blade screwdriver and 1 tap with a hammer is all i ever used, and neithr one ever wore out and got crumbly. <br>you seem to want to be STEALTHY--are yo up to No Good ???
also works with floppy disc protected with metal covers (break protector off break into halves break 1 half into another half) but works the same way!!!!
I just made this, and I am going to go to school and try this out on my gym lock.
LOL, me neither...
My method.
me neither
dont get it
Ditto. Ne neither.
Me neither.
me neither.
me neither
me neither
me neither
me neither
me neither
me neither
me neither
Me neither.
me neither
me neither
ok end this it gets very annyoing being email like 50 times a day from people replying
lol ok
Me neither. Wait, what are we talking about again?
Me neither x 2
just turn email alerts off
Me neither.
me neither
me neither
me neither. (I do, but I want to be a part of the group) =S<br/>
lol ya me to
Me neither
I GET IT!
HOLY CRAP!!! now explain it to the rest of us.
the U part of the M thingy slides into the gap between the lock-y-thing and the lock body itself. you wiggle it around, and it should pop the latch out, if you do it right. kinda like opening a door with a butter knife or credit card.
ya, i know. i wuz just kidding, although i wish the chain wouldd have kept going
falcon ruined it
tsk tsk.......
me neither
If your lock is of the kind with the keyhole in the back and you're really smart, just make a key. This requires a sacrificial lock from the same school. Then at the end of the year when the seniors don't need their locks anymore and lock them to stuff around the school you have a supply of free locks. I won't tell you how to do it though because if you're not smart enough to figure it out on your own then you're probably stupid enough to use it to break in and steal stuff.
Although, there is an instructable on the way to do it! <br />
ah man i love that arizona drink!
Did you that Arizona tea it's actually from NY.
I that Arizona tea it from NY.
what????
About This Instructable
411,923views
647favorites
License:
Bio: Working wireless-ly.
More by Tetranitrate:Laser Glow Board E-Bola Laser Tattoo
Add instructable to:
