Open Heart LilyPad Arduino Brooch
18,559
26
11
Published
Introduction: Open Heart LilyPad Arduino Brooch
About: Becky Stern is a content creator at Autodesk/Instructables. She has authored hundreds of tutorials about everything from microcontrollers to knitting. Before joining Instructables, Becky worked for MAKE Maga...
Here's how to combine Jimmie Rogers' Open Heart Kit with a LilyPad Arduino microcontroller board to make an animating LED heart brooch.
Here's a video of it in action:
Materials:
Open Heart kit or make your own
LilyPad Arduino
LilyPad AAA power board
conductive thread
scraps of fabric
embroidery floss
hot glue/epoxy
safety pin or pinback
solder
stranded wire
Tools:
USB cable regular to mini
LilyPad programmer
soldering iron
pliers
wire strippers
hot glue gun
wire snippers
scissors
sewing needle
Step 1: Assemble the Open Heart
Assemble your Open Heart according to the instructions on its website. Make some fancy animations using Jimmie's easy Flash program that generates the Arduino code you need. No programming experience required!
Step 2: Assemble the Heart/lilypad Sandwich
Cut out two pieces of scrap fabric (I used ultrasuede because it's thick without being too fuzzy) and sandwich them between the heart and the LilyPad. They help insulate the various conductive materials involved.
Step 3: Sew the Sandwich
With the heart and Arduino back to back, figure out which pins on the heart line up with which pins on the arduino, and write them down. You'll need to plug those into Jimmie's code generator when you program the board.
Sew those same pins together, hiding the knots between the two fabric layers so they don't flop around and short out your board.
Step 4: Adding Power
Because I chose to dangle my heart from the power source, I needed to make the positive power lead be on one side of the board and the negative be on the other. To do this, I first tried using conductive thread, but had a short I couldn't find, so I decided to redo it with just a little bit of insulated stranded wire. Solder a small piece from the + on the LIlyPad across the board to one of the analog inputs.
I used two more pieces of stranded wire to make the dangly connections between the battery board and the main board. I had to bridge the + on the battery board over to one of the unused pins on the opposite end of the battery holder to keep the dangly wire supports symmetrical. I used conductive thread for this; you can see it on the back of the battery board.
Step 5: Pin It Up
I used hot glue, and we'll see how long it holds, but you should really use epoxy to attach a pinback or, in my case, safety pin to the back of the battery holder. Make sure it's not touching any of the metal or conductive parts on the battery holder, or insulate those with more hot glue or epoxy. Use a little bit of embroidery floss to stabilize the top end of the dangly part, as shown in the picture.Pin it on, and you're done!
With this configuration, you have access to the programming pins on the LilyPad to change the animations any time you like.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    11 Discussions
    Nice! please let me know....... any fire risk?
    Amazing combination!!
    I love the t-shirt. Color Contrast with back ground and text is beautiful.
    You should check out Customizo.com to create your own custom t-shirt. We have a state-of-the-art design studio offering tools and features giving you the capability to upload and edit your own design, or use one of our custom design templates. Look at some of our design ideas if you need help getting started. GIve it a try!
    There are places that will make short runs of one or more of a shirt you'd like:
    Like Vista Print for instance.
    Custom Ink
    is another
    OR you could type in T-shirt into the search engine here, and do your own :-)
    God that bekathwia is cute. She is like a little highly-skilled, tool using ginger dinosaur.
    Great project.  I just finished a project that yours helped inspire.  Thanks for the ideas.
    http://www.flickr.com/photos/imakefunthings/sets/72157623625160334/
