Step 10Hardware - Printing Envelopes
We start by printing what is inside each envelope. As the envelopes we use (#1 and #6 Coin envelopes) are quite a bit smaller than normal mail envelopes finding a printer that will print them happily is nearly impossible. Our problem was solved when we happened across an old ink-jet printer at our local thrift store ($2.50). It's absence of a paper presence sensors, and easily modified paper feed tray made it perfect.
Quick Envelope Summary
ENV 01 3 mm Hardware - small
- BOL-03-10 3mmX10mm Machine Screw (x12 +2)
- BOL-03-15 3mmX15mm Machine Screw (x20 +4)
- NUT-03-01 3mm Hex Nut (x34 +4)
- WASH-03-01 3mm Washer (x12 +4)
- BOL-08-25 8mmX25mm Hex Bolt (x2)
- NUT-08-01 8mm Nut (x2)
- BEAR-01 Skate Bearing (x2)
- ELEC-01 Arduino Board (x1)
- ELEC-07 Breadboard (x1)
- ELEC-06 Quad AA Battery Box (x1)
- Wire-99-P-15 15 cm purple wire (22Awg Solid) (x2)
- Wire-99-R-05 5 cm red wire (22Awg Solid) (x2)
- Wire-99-B-15 15 cm black wire (22Awg Solid) (x1)
- Wire-99-B-05 5 cm black wire (22Awg Solid) (x2)
- ELEC-09 2.1 mm Plug (x1)
- ELEC-10 9V Battery Cap (x1)
- ELEC-11 3 pin header (x2)
- SERV-03 Continuous Rotation Servo 2
- RING-01 11.7cm ID O-ring (3/16" bead) size 349 (x2)
- RING-02 2.2 ID O-ring (3/16" bead) size 315 (x1)
10-OPNM-Envelope Summary - Summary of each envelope's contents
(ENTL) - Large SERB Envelopes.cdr - Large Envelopes
(ENTS) - Small SERB Envelopes.cdr - Small Envelopes
10-OPNM-Envelope Summary.pdf(612x792) 11 KB| « Previous Step | Download PDFView All Steps | Next Step » |
comment
Add Comment
Add Comment
