Attachable Dry Toilet - Prototype 2 (Banheiro Seco Acoplável - Protótipo 2)
Published
Introduction: Attachable Dry Toilet - Prototype 2 (Banheiro Seco Acoplável - Protótipo 2)
History: This prototype was developed by me in the context of a social business project, named S+ (Sustainable Sanitation), incubated at the Yunus Social Business Brasil (1st cycle). Also participated in the project Thais Cosa, Cecília Rodrigues, and Ilana Goldsmid.
Warning: You are required to have knowledge on composting techniques before trying to build/use this toilet.
Features: UDDT (Urine-Diverting Dry Toilet); this project uses Separett® Rescue (but actually it could use any similar piece from another third party); reuses space of existing regular toilet; urine container; external urinol (optional);
Pros: reuses space of existing toilet, no need for extra space; collects urine for treatment ou use as biofertilizer; provides urinol for men; saves water (no flush needed).
Cons: urine storage for many days can cause extremely bad smell; not very simple to remove the urine container (this would require a door in the structure);
Note 1: you can use either the biodegradable bag or a bucket (10L). The recommendation is to use a bucket, because it is easier to remove/replace. In that case the structure needs to be a bit higher (about 5cm higher if you use a 10L bucket).
Note 2: to make it easier to remove the urine container it is recommended to include, in one of the sides or in the front, a small door.
Note 3: The piece of rubber balloon in the tip of the hose helps to prevent urine smell from coming back up through the hose.
Note 4: Instead of using recycled plastic (6mm thick), the structure can be made of plywood (1cm thick) .
Step 1: Side Structure
Step 2: Urine Container and Urinol
Step 3: Cover Structure
Step 4: UDDT Separator and Biodegradable Bag
Separett® Rescue has been used, but it could be a different one with a similar purpose.
Step 5: Feet Platform
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    • Backpack Challenge
      Backpack Challenge
    Very interesting idea!
