3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Open locked door with zipties
Earlier today I was bored and tried to open a locked door with a card (like they do in the movies). It was easier then I thought (there is probably an indestructible on it somewhere, but here is the wikihow article http://www.wikihow.com/Open-a-Door-with-a-Credit-Card), but it only works if your on the correct side of the door (with the sloping side of the latch facing you). So I tried to think of a way to open it from the other side and came up with this.
This tool like the card only works on one side of the door. But unlike the card it works on the side of the door that has the sloping side of the latch facing away from you.
This dose not work on doors with deadbolts.
This tool is made of a paperclip and 3 twist-ties.
Disclaimer: THIS SHOULD NOT BE USED TO BREAK THE LAW
On a side note, I apologize for any spelling errors/wrong use of words. Spelling and spell check are two things I can't seem to get a good grasp on.
Step 1How it works
How it works
How it works:
The wire loop is pulled down on the sloped part of the latch. The latch moves in order to allow the wire to move down. When the wire reaches the end of the latch the door can be opened but only in that instant.
25 comments
Apr 18, 2012. 9:34 PM11877 says:
Instead of going through all this can't you just use wire ?
Jan 3, 2011. 8:26 PMT_T_ says:
you could also add solder to that twist to make it stronger
Dec 21, 2009. 5:51 AMpatowc963 says:
So let me get this straight...
YOU are in the INSIDE of a room trying to UNLOCK the door when the little BUTTON is right there....
Please explain to me the purpose/logic of this instructable?
Everyone, if you really want to unlock a door, get a set of picks.
Jan 3, 2011. 8:03 PMT_T_ says:
this would work well school doors, any other door though is pointless
Mar 3, 2010. 2:50 PMmr. clean says:
this will unfortunately only work with doors that swing out to go in the room.
Feb 26, 2010. 4:34 PMsalomon1996 says:
just use a credit card! lol
Feb 15, 2010. 8:44 PMIan01 says:
It would probably be easier for most people to just get a wire of the right gauge and length than burn and put together some twist ties. Related: why does the title say "zipties" when you're using twist ties?
May 18, 2009. 5:19 AMsilencekilla says:
lol i have those same needle nose pliers
Dec 15, 2009. 5:17 PMcdousley says:
me to
Jan 23, 2010. 10:10 PMmadhops0620 says:
haha I do too
Dec 15, 2009. 5:15 PMcdousley says:
i got the same pliers
Sep 7, 2009. 6:37 AMColonel88 says:
Yet another reason why to use dead-bolts...
Sep 5, 2009. 11:32 PMnave says:
my friends and i used to use butter knives to do this
Jun 8, 2009. 2:35 PMelectrick says:
Why not just pull the paper/plastic off?
May 15, 2009. 10:57 AMharrypoter says:
something is wrong with your system.to open a locked door your system should be design to use from out side.But this one is design to use from in side.
May 14, 2009. 3:07 AMfegundez1 says:
why not just use a small gage wire?
May 14, 2009. 8:13 AMmikeasaurus says:
why not just use the persuader?
May 14, 2009. 8:53 PMhominid says:
good one!!!
May 13, 2009. 7:48 PMkarossii says:
One important note: those are not zip ties; they are twist ties. A zip tie is a plastic or metal band with teeth, that seal by sticking the teeth through a little locking mechanism on the other end. Some (most) can only be used once, others can be released and opened to be reused. A twist tie is simply a very small gauge wire inside a plastic or paper sheath, which can be twisted into various shapes.
May 14, 2009. 5:00 AMHolden_vy_s says:
Yep, was going to mention this.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:4455221
