Open a Screw Back Case Watch With Scissors
275,411
Posted
Introduction: Open a Screw Back Case Watch With Scissors
You don't need a special tool to open a screw back case watch. Just one of these.
Step 1: Watch Example
I'll use my 'Rip Curl' watch as an example.
Step 2: Watch Back
Look closely at this image. You'll see notches that are cut out of the watch back.
Step 3: Scissor Tips Match to Notches
Now all you need do is insert the scissor tips into two of the notches. Make sure the blades are securely in position before turning the scissors anti-clockwise.  The scissors need to be perpendicular to the notches, (not as pictured).
DISCLAIMER: Please be aware that scissors are not the correct tool for this task and in any case this procedure would probably invalidate a warranty. Scissors have sharp cutting blades and the potential for bodily harm and/or scratch damage to the case caused by the incorrect use of scissors is higher than if the scissors are used as intended. Please be very careful. You are warned!
Step 4: Rip Curl Watch Internals
This watch is good to 100m. Here's the internals.
Getting to the battery
Having got thus far you don't want to cause damage getting your battery out. I would recommend using a magnifying glass to figure out how the battery is retained before attempting to remove it.
Closing the watch is just a reversal of this instructable. Have fun and be careful.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
6 Comments
I didn't think this would work on my old ripcurl watch, but it totally did. thank you!
I use a pair of needle-nose pliers, I foresaw myself putting two very large holes through my palm using scissors.
ouch! : ]
I hadn't thought about needle-nose pliers, but then I would have to go and buy some. I wouldn't use a lot of force with the scissors method. If you find the case is hard to unscrew it will be best to use an alternative (and safer) method.
Ah, very smart! I did watch repair for a long time and never thought to try something like this when I didn't have the right tool. :P
Thanks, but the idea isn't original. I read about it, tried it, and it worked. I get lots of useful tips from this site so I thought it's time to reciprocate.
