Introduction: OpenSAM 3D Printed Camera Stabilizer Steadicam Gimbal
The OpenSAM by OHM is developed for filmmaking amateurs and professionals. The design allows a broad spectrum of cameras of varying sizes and weights to be stabilized. The use of 3D printing technology for the mechanical construction means that it can easily be reproduced and any design changes are easily implemented. The 3D printed parts are also lightweight (actually lighter than any commercial carbon-based designs). All parts were printed in PLA using Ultimaker Original 3D Printers or Bq Witbox 3D Printers and the files have been made available under an open source license through our GitHub and website.
The brushless gimbal stabilization system uses three brushless motors to stabilize the axes. One 8-bit brushless gimbal controller (BGC), an expansion card and an IMU (Inertial Measurement Unit) is all the electronics needed for assembly. Our model seen in the video and pictures cost under $200 in parts, excluding the 3D-printed parts (which are free to print as students in Denmark). This should be compared to the price of similar gimbals, which start at around $1000.
Step 1: Diagram
Picture of Diagram
[1] Brushless Gimbal Motor (x3)
[2] Yaw joint
[3] Joystick case (contains joystick)
[4] Grip arm left
[5] Grip arm right
[6] Handle (x2)
[7] Bracket L
[8] Bracket U Bottom
[9] Bracket U Top
[10] Grip arm one-hand (Optional)
[11] Handle (Optional)
[12] Suggested mounting place for bat- tery
[13] (Back side) Suggested mounting place for yaw case
[14] (Back side) Suggested mounting place for main case
[15] Mounting place for IMU
Step 2: Get and Produce the Parts
Picture of Get and Produce the Parts
3D printed parts
Print all the 3D printed parts using your 3D printer. We used Ultimaker and Witbox 3D printers. We refer to the manual at our website for a detailed description of all the parts and tips on printing.
Third party electronics
You'll also need some third party parts. We refer to the manual at our website for a detailed description of all the parts and links to webpages where we obtained these parts.
  • Electronics set with IMU such as the BaseCam SimpleBGC 8-bit Set (x1)
  • Brushless gimbal motors (×3)
  • Battery (×1)
  • Joystick with button (×1)
Generic parts
The following generic parts are also used. Again, we refer to the manual at our website for a detailed description.
  • M2.5 Screws (×9)
  • M3 Screws (×14) and M3 nuts (×2)
  • M4 Screws (×3) and M4 nuts (×3)
  • Wood Screws (×2 + ×2)
  • Camera mounting screw (×1)
  • Reattachable fasteners (ca. 40 cm)
  • Cable extensions (optional)
Step 3: Assemble OpenSAM
Picture of Assemble OpenSAM
  1. Part [15] is mounted underneath part [7] using two 4.5mm bolts and nuts.
  2. A motor (part [1]) is attached on the back of part [7] using four M3 bolts. Choose the holes on part [7] so that when a camera is mounted in one of the two bottom holes, the camera’s center of mass will align with the motor’s rotational axis.
  3. Mount part [8] on the motor (part [1]) using three M2.5 bolts.
  4. The case for the BaseCam mainboard is placed at position [14] at the back of part [8] using a reattachable fastener of your choice. If anything should ever brake or a part should get updated, replacing the part is that much easier.
  5. The BaseCam mainboard is mounted into the case
  6. Put a new motor on part [8] using four 3mm bolts.
  7. Part [9] is put through part [2] and attached to part [8] using a 4.5mm screw in one side, and three M2.5 bolts on the motor (part [1])
  8. Put part [4] and part [5] together using M3 bolts and nuts, to assemble the handlebar.
  9. Mount the last motor (part [1]) on the handlebar using three M2.5 bolts. If the onehanded grip (part [10]) is used, it needs to be mounted in between the handlebar and the new motor and thus the M2.5 should be 25mm long.
  10. Put the handlebar through part [2] and mounted to the upper motor using four M3 bolts.
  11. Use two 4mm bolts and nuts to fasten and position the camera’s center of mass so it aligns with the motor’s rotational axis.
  12. Mount both parts [6] to the handlebar using two long (approx. 80mm length) woodscrews.
  13. Put the joystick into part [3] and mount it to the right part [6] using a tie-wrap. Wire the joystick by connecting the onboard 5V and GND to the joystick and connect the BTN on the mainboard to the SW and GND on the joystick. This means that you have to merge two cables into one GND pin on the joystick. Lastly, the VRy and VRx on the joystick go into RX_ROLL and RX_PITCH on the mainboard.
  14. If part [10] is mounted, attach part [11] using proper sized woodscrews.
  15. The case for the BaseCam yaw board is placed at position [13] at the back of part [8] using a reattachable fastener of your choice.
  16. The BaseCam yaw board is mounted into the cas.
  17. The battery is placed at position [12] at the back of part [8] using a reattachable fastener of your choice.
Step 4: Configure OpenSAM
Picture of Configure OpenSAM
Depending on your choice of electronics, once OpenSAM is assembled, some settings need to be tuned in.
We refer to our website for a description of the settings we used for our SimpleBGC AlexMos system. See screenshots here if you want a quick idea.
That's it!
Thank you very much for reading this Instructable and happy printing/filming!
José Á.F4 (author)2018-01-17
Hi. As commented, please can you share the motor characteristics?? It's important as the printed piececs should fit (bolt holes) into them as per inertias and power to handle the DSLR camera.
Zenography (author)2017-12-01
you guys have done a great job, I will definitely give you a credit in our film.
AndréM143 (author)2017-04-25
I'm from portugal and want to say thank you. Cause this tutorial is just perfect !
eGadgetGuy (author)2017-01-14
I want to make this. I have two cameras that it might work with. One is small enough for the design as is. The other is too big. Much too big. It is 11 inches long and weighs 6 lbs. So I was thinking... would this work if the camera was above the whole frame? would it need much stronger motors? Would I have to beef up the motors if I figured out how to make it as is, but just larger? I imagine the camera rig being shoulder mounted for the large camera. But would a single sided gimbal arm be needed to overcome the size problem or is it necessary to use the "U" shape for stability?
TIA
blakio (author)2016-10-15
Hey Question?? .. Would mounting holes for the motors work with ipower 5208 motors?
lucianorueda (author)2015-07-22
hi! I am trying to make this instructable!,i have one question...
I have one question, I order this controller, from the seller "vocanlo"
http://www.ebay.com/itm/151696893687
but I got another controller!!! (it looks exacly like the one in this picture, from another seller)
http://www.ebay.com/itm/MINI-BaseCam-SimpleBGC-8bi...
the problem is that I dont see any Inertial Measurement Unit (IMU) board, so I dont know what can I do with this!!!!
in the board it says BASECAM electronics v1.1, if that helps...
in the description of the item, there is a link, to upgrade the firmware,
http://www.simplebgc.com/eng/downloads/
and there it actually says that this seller "Vocanlo" sales fake copies of SimpleBGC controllers!!!!
So I am scrued I know...
But I wanted to ask you guys because maybe I can use this controller anyways... what do you think?...
Please help!!!
Thanks in advance!
Luciano
marlonr (author)lucianorueda2015-09-10
Luciano,
Perdona por el español, pero creo que puedes usarlo de todas maneras. He compraado exactamente el mismo controlador, de HKing, aunque no es el mismo suplidor, son exactamente los mismo...
Espero que reportes si te ha funcionado.
slds
StudioC1 (author)2015-08-26
Increnable! Very great idea, congraluations Boys
johanmoberg (author)2015-05-21
Very nice and fast! I have two suggestion/ideas. 1. Rigg isn't very ergonomic; good for short fast shoots but for longer filming your arms are going to hurt. Perhaps add two mounting brackets on each side of the camera (on the top rail) where you could slide in shoulder support arms, joined with an empty plastic container behind your shoulders (like a U). In this container you could put sand to get a decent torque equilibrium. 2. Would be great if camera could travel +- 5-10 cm straight up and down, then you could stabilize walking/shaking/bouncing even further.
OpenSAM (author)johanmoberg2015-05-25
Thanks.
1. As you can see in the CAD design, we have prepared for a handle to be able to be attached to the middle of the rig. Due to time constraints and some missing screws, we ended up not using it, but I think it could be easily modified to allow for over-shoulders suspension to be attached.
2. That would be great. We thought about it, but for simplicity did not proceed with that idea. That could be a feature for the next version! :-)
tomatoskins (author)2015-05-19
Very cool idea! Thanks for sharing!
About This Instructable
15,109views
122favorites
License:
Bio: We are a team of three students with a passion for electronics and robotics. Recently, we have made a 3D printed camera stabilizer called OpenSAM ... More »
More by OpenSAM:OpenSAM 3D Printed Camera Stabilizer Steadicam Gimbal
Add instructable to:
