Building the Wood/Epoxy Optimist
In 1947 a gentleman named Clark Mills designed a small sail boat for kids to learn to build and sail called the Optimist.  This boat was designed to be built from 3 sheets of plywood, with basic woodworking abilities.  As time progressed, builders began to modify the boats to gain speed advantages - as happens with all vehicles.
In 1995 the International Optimist Association took the boat back to its roots and a set of dimensions were compiled to retain an exact shape of the boat, so as to remove design advantages from one boat to another.  The Optimist is tightly controlled now with over 60 measurements and tolerances of the hull are generally +/- 5 mm.  The tolerances do not allow the builder to exploit the possible variations of shape of the hull, but do allow a competent builder to construct a legal racing hull.
Half Moon Bay Yacht Club has a summer youth sailing camp.  Through the years we have trained many a young boy or girl to rig and sail the small boats available to us.  Normally in an older Laser or Coronado 15.  In 2011, the sailing program decided that the Optimist had a place in our sailing fleet to allow the younger kids (7-15) to rig, launch, sail and retrieve the boats themselves while under adult supervision.  We set about looking at the building of wood/epoxy Optimist sailing boats.  We quickly focused on making racing legal hulls so as to be competitive with other surrounding sailing clubs.  This is where the accuracy and repeatability of the ShopBot CNC router at TechShop of  Menlo Park www.techshop.ws became an invaluable tool in our fleet building.  I made it at TechShop.  Due to the close tolerances allowed, and the desire to have an almost identical fleet of boats, the ShopBot  fit the bill to the letter.  Once I redrew the plans into CAD drawings and transferred to cut files the different parts of the boats were identical.  Each group of people that wanted to build a boat only had small amounts of fitting, beveling and gluing to accomplish, with very little use of dangerous equipment needed and quick progress to show for their efforts, so kids fit right into the task of building boats.
Step 1:
The jig produced on the ShopBot retains the correct shape and supports the boat, while it is being built, to retain the exact design measurements.  The plans for the boat can be found from many sources for free on the internet.  Plans are available in many languages, as well.  One such source is http://www.optiworld.org/Woodguide05.pdf
Another guide to building an optimist is http://www.burcotboats.co.uk/howToBuild.pdf , as well as half a dozen other well written articles on the internet.  But none provide CAD quality drawings or files to work with modern computer controlled machine tooling.  Well, here they are:  The jig as well as the major parts of the boat.    The jig sides , mast step, rudder, dagger board , dagger board case ends and doubler pieces are made from 18mm or 3/4" ACX or marine grade plywood; (1219.2mm x 2438.4mm) 48" x 96".
Now to get started, the jig we have designed is the exact dimensions of a finished hull shape.  Both ends of the jig have interlocking pieces to allow for inserting and removing as needed during the building of the boat.  The cross members are standard 2" x 4" cut to 44" long and with a 3/4" dado 8" to each side of center to fit into the grooves of the forms.  These should be cut so as to be flush with the top of the form and screwed into place to prevent movement.  The bottom boards provide a stable platform for the jig to sit on.  The jig should be placed on a flat surface for the build, as distortion to the jig will transfer to the boat being built.   Save the scraps for blocking.
1-40 of 41Next »
ssmithsonian says: Mar 19, 2013. 10:05 AM
So how much would one of these cost to make in it's simplest form? Like, a Home Depot budget form?
superdave.morris (author) in reply to ssmithsonianMar 19, 2013. 10:27 AM
We figured our cost per boat about 400. We purchased prefab sails, daggerboards and rudders due to the kids beating up the wood ones. The FRP daggerboards and rudders hold up better.
smiley G.I JOE says: Oct 18, 2012. 10:49 AM
hope you get a kick out of this one.
smiley G.I JOE says: Oct 17, 2012. 7:22 AM
my point is to make a sail boat able to sail freely on a lake. what i want is to make a boat like this.
smiley G.I JOE says: Oct 16, 2012. 6:23 AM
could you extend the frame and add a second sail.
superdave.morris (author) in reply to smiley G.I JOEOct 16, 2012. 11:19 AM
If you did, it would in no way be an opti. Could not race in the opti class and there fore would be a one design sailboat. Which you could do. But it won't be an opti. The purpose of the instructable is to make a legal, measurable, race able opti....
I will add a bit to this to say we built 7 of these boats for our club. Summer youth sailing camp totally sold out and we even added 2 more weeks. Now we have an after school program going this fall. These boats have been an great addition to our sailing program. They took their fair share of bumps and hits and I think held up better than a Fiberglass one would have. You can see pictures on www.hmbyc.org.
Mick B says: Apr 24, 2012. 3:08 PM
Superdave,
I have sent those DXF files to a friend who has a cabinet shop with a CNC router. I will wait until your updated files to go forward. These machines can do bevels? Would a designed-in bevel on the bottom panel edges save some work?
superdave.morris (author) in reply to Mick BApr 25, 2012. 10:02 AM
Just added the 18 mm dxf file as well..
superdave.morris (author) in reply to Mick BApr 25, 2012. 9:53 AM
I just edited the instructable with the 2 revised DXF files. These change the bottom width 2mm to bring it into the center of tolerance. I would just bevel by hand. A hand planer works great and takes 3 minutes. Programing time would be more than that. At the dry fit you can see if you need to add more bevel. The revision also moves the bottom outer doublers inward and adds to groove for these in the mid frame and mast thwart. The items on the second sheet of 12 mm are for the daggerboard case sides, daggerboard and rudder. For our club boats the 12mm daggerboard and rudder are too fragile. Probably fine in a private boat. On the DXF file the size of the plywood is drawn as an outer line for reference only. Superdave.morris@gmail.com
Mick B says: Apr 23, 2012. 11:57 AM
Superdave,
You put the rudder and daggerboard on a file called 18mm cutsheet. According to the rules 18mm would be too thick for those items...
3.3.2.2 The thickness of the daggerboard (excluding bevels) shall be not less than 14 mm (12mm for wooden construction) and not more than 15 mm.
3.4.2.2 The thickness of the rudder (excluding bevels) shall be not less than 14 mm (12 mm for wooden construction) and not more than 15 mm.
superdave.morris (author) in reply to Mick BApr 24, 2012. 10:25 AM
And 12mm is too thin and fragile for our club boats. So the belt sander and the layers of ply for guides makes for a easy shaping of the material to end up with the desired thickness, contour and shape. You could also cut it out of a 12mm and 4mm but would require you to buy more wood. Belt sander is quick and easy. With the DXF files there you can pull any piece out of the drawings to cut it out of what ever material you like. We are actually buying the rudder/dagger board FPR combos for our club boats due to the fact that the kids run the boats aground and the dagger board takes a great deal of abuse. A private boat probably wouldn't see that abuse.
Or run it through a planer a pass or two... And again the 12 mm version for our club wood boats is too fragile...Thanks for the critical analysis of it. Sounds like your serious. I have tweeked my drawings a little on our #6 and 7 boats. When I get the time I will post them. Change of the position of bottom doubler inward slightly, mast thwart outward 2mm and bottom 2mm wider at 1 spot. This hits the measurements a little more to middle of min and max.
he who crashes often says: Apr 19, 2012. 9:16 PM
hello, long time sailor, first time building one. i am looking to build a 12-14 foot FJ/420/topaz type sailboat (2 person, mainsail and jib). any ideas? i was thinking of making it pretty much like a longer version of an opti (preferably narrower beam to length ratio than an opti though, as otherwise i would be looking at about a 6-8 foot wide boat.)
superdave.morris (author) in reply to he who crashes oftenApr 20, 2012. 6:42 AM
Why not go buy a used C-15. Just buying the hardware new for a boat like you described will cost probably 2x as much as a used C15 with a trailer. A friend of mine just bought a nice one off Craigslist for 600 with trailer and new sails. Needed a repair in the bow where it got T-boned but that took about $40 and 4 hours and now she has a great boat. Boat market is real soft here in the bay area. Put out a shingle on Craigslist for wanted small boat and go visit your local marinas and ask about abandon boats as well as boat storage yards for abandon boats. These Optis are so easy and inexpensive to build compared to most other boats is the only reason I would build these over buy them...Plus the fun/learning factor for the kids. Good luck...
he who crashes often in reply to superdave.morrisApr 20, 2012. 9:25 AM
are you suggesting i buy instead of build?!?!? you, sir are NOT WORTHY of being a member of instructables. (jk, i see the logic, but i want to have something that i built and can be proud of.)
Mick B says: Apr 18, 2012. 3:09 PM
You can download the official Optimist plans for free from the USA Optimist site. The International site will charge you. Go to http://usoda.org/ and click on FAQs and then Wooden Boat.
nsijan says: Apr 1, 2012. 11:12 AM
Hi , Can u tell me where did u find plans? I would like to build one boat for my kid, but your pictures are too small to use them :(
aqwiz in reply to nsijanApr 12, 2012. 1:40 PM
You can also find not only plans, but ready to assemble kits at http://bateau.com. as well as all the supplies needed to assemble a boat at http://boatbuildercentral.com they supply the Youth Sailing Foundation of Indian River County (Florida).
superdave.morris (author) in reply to nsijanApr 1, 2012. 12:36 PM
Links are in the instructable as well as several others in different languages also.
You can use one of the free online drawing programs to open the different dxf files.
anode505 says: Mar 4, 2012. 3:08 AM
You're allowed to build your own Opti? (for racing?) That's SO cool. A GREAT Father/Son (or daughter) project.
Love One Design (just not a fan of One Design One Builder)
Always wanted an Opti, just so I could name it Fat Man in a Bathtub
l8nite says: Feb 24, 2012. 11:43 PM
That's a gorgeous little watercraft, it reminds me of my very first boat except the "pram" had a small deck and a removable seat over the dagger board well for rowing. Very nicely laid out "ible" thank you for sharing
b0bb0 in reply to l8niteMar 3, 2012. 4:56 PM
I built an 8' pram very similar to this in 1961 at the age of 13 with ZERO help from anyone once I had the supplies. Paid for the whole thing myself with my paper route. Sent away for plans I saw in the newspaper or a magazine.
I built it as a rowboat to use on Lake Erie, about 500' north of my house. The hull is curved and the whole thing is a bit more graceful. With one person onboard, it moves pretty good! Had a few scary times in Lake Erie, but survived them all! Very interesting ride with two folks and whitecaps.
I still have it and last used it about 15-20 years ago at Kelleys Island when my kids were smaller. Now I might have to take it out of mothballs and give it another summer. Sucker is going to be 51 years old in a couple months!
Thanks for the great article!
eddythedog says: Feb 28, 2012. 7:03 PM
Great job on the instructions. Looks like a fun boat for the kids. Is there a bigger version for big kids (adults).
a4great in reply to eddythedogMar 2, 2012. 6:39 PM
For adults? i don't think so...
Uptonb says: Mar 2, 2012. 4:29 PM
Congrats on being a finalist, and good luck!
ironsidesnh says: Mar 2, 2012. 4:46 AM
Ahoy superdave.morris!!!
In the honor of my Fave Military Drama Show still on now. Your a bunch of Juinor " USMC Gunery Sergent / Special Agent Jethro Gibbs N.C.I.S. " in the making with this instructable! Awesome Job matey's! Make & Made Shipshape & Bristol Fashion! Thank you for a great job here keep it up , I'm looking forward to larger craft you might do again... And in the theme of another name droped As Old Master Yoda always says "Do, or Do not, there is no try" , becase in your future projects note I did not say or imply at any time the word "try" in any point implied. You do good work!
Great Awesome instructable here....8Dbd
Keep me informed thank you!
theawesomeninja says: Feb 26, 2012. 9:47 PM
Say we weren't making a race-legal dinghy...what can we do to improve performance? Making it sleeker? Sanding the outside?
he who crashes often in reply to theawesomeninjaMar 1, 2012. 7:41 PM
you would want to make it narrower at the bow, and a shallower angle on the bow too. this will make it skim the water rather than moving it out of the way like a snow plow. i made a mini (4.5 foot by 3 foot) one for my 5 year old sister to sail while i sail a laser, and the shallower bow increases speed by almost a knot.
girvster says: Feb 27, 2012. 8:27 AM
I learnt to sail in one of these.
optimist is a rather fitting name for the craft lol
he who crashes often in reply to girvsterMar 1, 2012. 7:38 PM
they are great little boats (i sailed them from age 5 to age 12, when i moved to lasers and FJ's .) but they leave a lot to be desired, such as speed, comfort, lightness, practicality, and room to fit under the boom (i almost drowned once when it turtled with my life jacket stuck on the boom) but they can out-turn a pirana and are almost impossible to capsize. (although because they are almost square, i once capsized forwards while on a straight downwind run coming back from the golden gate bridge) what other boat can you capsize FORWARDS?!?!? that is why i love the opti.
arduinoer says: Mar 1, 2012. 4:10 PM
Why waste a great racing sail and spars on a wooden boat?
dudeman618 says: Mar 1, 2012. 12:48 PM
I really do like the look and design of your boat.  Congrats and enjoy sailing with it.
Your boat resembles the Puddle Duck Racers -  I have helped to make several and sailed a few. You can vary the design, we closed in airboxes so it floats under any condition. On a few we used bamboo for the mast and tyvek house wrap to make the sails. There are patterns online for the sails as well. I was surprised at how fun and sturdy the boats are to sail.
komar227 says: Mar 1, 2012. 7:15 AM
hallo,
thats interested, we build the optimist in the 60 and 70 in germany - east, GDR, German Democratic Republic. Pupils make regatta.
very nice - I remember me
vincent7520 says: Feb 28, 2012. 9:25 AM
great job ! …
for those who are not aware of what boat construction means, let me tell you : it is a hell of hard worth that asks for patience and time.
CONGRATULATIONS…
Fareastsails says: Feb 28, 2012. 1:25 AM
Thanks for sharing information on building
sailboat.
chawist says: Feb 27, 2012. 7:12 AM
Dave, can you bring it to the Great Lakes. It would be great for my high school student!
Pader says: Feb 25, 2012. 10:07 PM
I believe that these little craft are what used to be called the 'Mirror Dinghy' over here in the UK. Very nostalgic.. Thanks for a good instructable
dr_insane in reply to PaderFeb 26, 2012. 9:18 AM
No, 2 completely different boats, The mirror looks like a giant optimist with a gib.
frits297 says: Feb 25, 2012. 4:50 AM
nice work! how long did it took you to build?
superdave.morris (author) in reply to frits297Feb 25, 2012. 8:27 PM
We have a fleet of 6 being built for our club. The first 2 took about 2 weeks worth of free time if you added it up. Hour here hour there. One member is going to see how fast he can build and I would bet he will knock one out in a week fairly easy but he is a sharp guy and knows the drill so his learning curve is done. And all his parts are cut and ready to go. Enjoy the build if you decide to. It goes fast and is fun. Biggest thing is waiting for epoxy to cure. Some people I have heard have used polyurethane glue like liquid nails. Don't know how it has held up to long term use.
melley17 says: Feb 25, 2012. 7:06 PM
Lots of great detail. Thanks for sharing all your hard work so others might benefit.
1-40 of 41Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
