Optimizing an IKEA Wardrobe
49,609
60
6
Published
Introduction: Optimizing an IKEA Wardrobe
About: So many things to learn and make, so little time! I like things that are cool, useful, efficient, well crafted. Subscribe to me! If I inspired you, share it and you'll get a patch.
I have bought an IKEA (PAX) wardrobe with doors. When it came about the drawers, a design fault showed off: some unwanted and irregular space between the drawers made us loose some precious room.
Well, it may be a small annoyance, or a big one if you are a perfectionist!
Read on to see how to hack and save space. It will require a hand saw for metal, and a router.
Step 1: Using the IKEA Online Planner
They have an online planner on the web, which allows you to choose the wanted size, color, accessories.
After opting for doors, when placing the drawers, you may notice some unexpected spaces (marked "?!?" below), but the images are pretty small and faded, so you'll miss them easily.
The wasted space seems meaningless, but believe me, in practice, you'll notice it. The bad thing is that you cannot use that space at all.
Step 2: Why These Damn Extra Spaces?
But why, you ask, do these spaces exist? is there some sort of constraint?
The answer is: the door hinges are on the way!
Step 3: The Solution
Let's not be ruled by these hinges. The idea:
- make a cut into the bottom-most slide
- make a groove into the fourth drawer
Step 4: Bottom-Most Drawer
A hinge is on the way of the slide. use a metal handsaw to make a cut like illustrated.
Then, mount all four slide pairs, and place the three bottom-most drawers.
Gain: one space.
(There are still two spaces wasted at the very bottom.) But hold on, the best is yet to come.
Step 5: Fourth Drawer
A hinge is on the way of the fourth drawer. Mark the location on the drawer, and make a wide groove, using a router.
A router is a strange and dangerous power tool. Use a lot of caution and train on a piece of scrap wood! Wear protective glasses. Work slowly. Unplug the cord whenever tuning the tool.
Don't meet the screws: let at least 2mm of the thickness remain. The groove is quite wide, so make it in 3 passes, the center pass first.
Then place this drawer.
Gain: 5 spaces (almost the height of one drawer!)
Step 6: Done! Compact Layout
Enjoy the saved room, and the evenly spaced drawers.
Ambitious DIYers can even save the space at the bottom:
- make a longer cut into the slide
- you'll need to make a grove in the bottom drawer too
- be sure to do this first, as everything will be shifted downwards.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    6 Comments
    cut about 10mm from the top of the draws and they fit a lot closer together!
    ok, good idea but I think is more simple use blum hinge nil protrusion
    Hi. This is smart.
    But instead of using a router, I would have put the door hinge 10cm higher.
    A little easier no?
    "A router is a strange and dangerous power tool"... very wise words!
    Lose not Loose. Loose = not tight.
    Great fix.
    ...or waste, not waist.
    Fixed the fix. Thanks.
