Optimus Prime Lego Instructions
Introduction: Optimus Prime Lego Instructions
This is a robot and I like the way it looks.
Step 1:
Get these pieces.
Step 2:
Attach the red grabber pieces to the black cylinders. Then put the black cylinders onto blue 1-dot pieces. Put the blue 1-dot pieces onto into the 1-dot pieces with the side dot. Put the slanted blue pieces on top.
Step 3:
Put a red grabber piece onto the side dot of the 1-dot plus side dot piece. Put a hose end piece into the red grabber and then clip a clipper onto the hose piece.
Step 4:
Take a gray 2x2 piece and stack two red piece with a white circle in the middle.
Step 5:
Put the stack of the two red pieces with the white circle in the middle, on one corner.
Step 6:
Put the gray 2x2 with the red and white stack onto the pieces you made before by putting the other side of the clippers onto the gray 2x2.
Step 7:
Put 2 thin 1-dot pieces on the bottom of the gray 2x2.
Step 8:
Put a thin 1-dot piece that is as large as a 2-dot piece but only has 1 dot in the middle into the bottom thin 1-dot piece.
Step 9:
Put another thin 2x2 onto the piece that looks a thin 2-dot but only has one dot in the middle.
Step 10:
Take two 3-dot wing pieces and one corner piece with 2 dots on each side.
Step 11:
Put the wing pieces onto the corner piece.
Step 12:
Attach the corner piece with the two wing pieces onto the bottom of the thin gray 2x2.
Step 13:
Put two slanted vent pieces on the wing pieces.
Step 14:
Put a thin two dot piece on the back of the wing pieces.
Step 15:
Get two thick 2-dot hinge pieces.
Step 16:
Put the two thick 2-dot hinge pieces onto the thin 2-dot piece.
Step 17:
Put two corner pieces with two dots on each side onto the thick 2-dot hinge pieces.
Step 18:
Put two 1-dot slanted pieces onto the corner pieces with two dots on each side.
Step 19:
Put two wing pieces onto the slanted pieces.
Step 20:
Put two smaller 1-dot slanted pieces onto the wing pieces.
Step 21:
Put two glowing blue slant pieces onto the small 1-dot slant pieces.
Step 22:
Put two thin 2-dot pieces onto the back of the wing pieces.
Step 23:
It is finished! Here is Optimus Prime!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
