3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Optionally magnetic screwdriver
Kind of more of an idea then a complex instruction but one that hadn't hit me before and made me go "Why didn't I do this before"?
Magnetic screwdrivers are very handy for keeping screws, especially those so small they are barely visible, stuck to the screwdriver. However, also very unhandy around disks, hard drives, TV sets, etc and not all screwdrivers are in the first place and can be in the way getting the screws off it. With a ferromagnetic but not magnetized screwdriver and a neodyme magnet, you can have it both ways.
Step 1Put it on
Put it on
Attach the neodyme to the screwdriver. This temporarily magnetizes the whole thing, strength depending on magnet and closeness to the tip.
17 comments
Aug 17, 2011. 7:46 AMdactadork says:
great idea, but quick ocd moment: hard drives are not affected by magnets, as a matter of fact, there are 2 decent-sized neodymium (aka VERY POWERFUL) magnets enclosed in them
Mar 27, 2007. 12:51 PMMysticX says:
It actually takes a very strong magnet to mess with a hard drive. I have used magnetic screw drivers on computers for years with no problems. I used the magnet on / magnet off technique once to attach a floppy drive once in a case with very poor access. Overall, a nice instructable which will help other from facing that frustration.
Mar 27, 2007. 1:55 PMLasVegas says:
Mystic's right about hard drives. Even floppy drives would have no problems with a magnetic screwdriver. I wouldn't recommend using a floppy disk to rest the screwdriver on though.
As to TVs. Again, a magnetic screwdriver shouldn't be a problem when used to remove/insert screws. Never (read NEVER!!!) use a metal screwdriver of any sort to calabrate a TV or monitor. Always use plastic tuning tools.
Jul 17, 2010. 12:43 AMcdousley says:
my tvs still got a purple spot from when i was young and stupid (about 7)
Nov 13, 2009. 7:55 PMcarlosdreyfus says:
I prefer my screwdrivers to be permanently magnetized, just by sliding the Nd magnet, in one direction to the tip of the tool it gets magnetized and can hold all the small screws.
Nov 13, 2009. 5:12 PMlucanos says:
I have had to use magnetised screwdrivers on a number of occasions (although mainly when working on cars - same principle, if somewhat larger tools and screws/bolts).
Other methods for magnetising the screwdriver which I have used are:
Rubbing with a Magnet
Rather than attaching the magnet to the screwdriver, just running it along the shaft of the screwdriver (a few times, and in one direction) will pass on a weak, temporary magnetic power. Not perfect, but when you are working around alot of ferrous parts and you just need enough "stick" to hold the screw, it can work wonders.
Shock the Screwdriver
Sounds strange, but is a trick I picked up from a mechanic friend - you get some cable (almost any gauge) and twist it around the shaft of the screwdriver (rolling it in one direction and from the handle towards the tip). Touch the ends to a battery for a short period (only a second or two - otherwise, you may melt off the insulation, or screw the battery) and now the shaft should be somewhat magnetic.
Both of these methods are temporary, and not terribly strong, but may also be options for some jobs. Of course, using the second method should never be used with any power source other than a car/bike battery (mains power tends to tickle).
Sep 5, 2009. 10:26 PMtanmanknex says:
Are you serious? I just barely helped my dad fix our fridge this exact way the other day! We had an awkward crew position and I put magnets on the screwdriver to position the screw! Well, great minds think alike ;D
Sep 6, 2009. 8:30 PMtanmanknex says:
True. GO MAGNETS!
May 24, 2009. 1:42 PMampeyro says:
there is anither way to do this, you can open the transformer of an olt microwave oven, i accidentaly magnetized most of my iron tools when trying to repair it
Mar 28, 2007. 8:29 AMich bin ein pyro says:
and its neodymium i think dictionary is sometimes wrong
Jul 15, 2007. 8:38 PMnewkiraj says:
ya its neodymium
Mar 28, 2007. 8:26 AMich bin ein pyro says:
ive tried this before never actually screwed something in but it was fun to play with
Mar 27, 2007. 1:35 PMxboxteen01 says:
cool,i once considered an electromagnetic type but this is much easier. i may still try one out though.nice job
Mar 27, 2007. 1:29 PM!Andrew_Modder! says:
yeah, when i get a new screw driver or drill bit, i magnatize them. (its a pain to screw stuff into small places with a non mag-tized driver) I reccomend using a neodynium magnet (get 2 of em from a old hard drive.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
40
Author:LarrySDonald
