- Night rider steering wheel
- Side skirts
- modified front and rear bumper
- EVO style fog lights - (6" PVC plumbing pipe had even a local body shop guessing)
- Aluminum wing
- Beetle back hood scoop - inside the scoop in the engine bay i had mounted a rotating red emergency light. At night coming through the cracks it had a pulsating look - was actually quite proud of how cool it looked, still am!
- Under lighting
- Interior lighting
- Custom molded gear shift
- hand sewn neoprene seat covers
- One piece rubber floor - cut from a old Russian water bladder used on ocean vessels, it had a drain in the rear that was from an old claw foot tub. To clean the inside of the car you just took a pressure washer to it, then pulled the rubber stopper to drain it.
- Most of the body was replaced piece by piece with used stainless steel motor guards pounded into shape from where I work. These motors are almost as large as the car itself, to give you an idea of the size of the guards!
- And the orange crush paint of course, the paint booth we built in the front driveway drove the snooty neighbors across the street nuts. love it
- These cars had a 3 cylinder high compression motor, what that means is when gas was about 1$ dollar a liter, i could fill the the 30 liter tank for about 30 bucks and drive just under 700 kilometers or about 430 miles.
- On one of my many road trips i found myself in Edmonton Alberta in the dead of winter. Stopped at a stop sign on a icy street, I noticed in my rear view mirror a brand new Honda accord spinning out of control on the ice, about to hit my little car. It hit me so hard, that the steering wheel i was bracing against - bent. I got out of the car and discovered the only damage was the left rear corners light was shattered and the plastic cover on the bumper was cracked and bent into the rear wheel well. I got out and bent the metal back into place. I was able to drive away with minor repairs. The Honda though, had its left front wheel now horizontal, the front end was smashed and the motor was sitting on the ground still within the confines of the engine bay. I drove away and went for tacos
- I bought it for 700, back then it had about 120k on it, when I sold it for 500 almost 5 years later the speedo read just under 600k. The cars life span was rated to about 180k. Only big repair was I replaced the first exhaust valve and head gasket, they always go on these engines.
- It was just plain fun, so peppy and great in the snow - (look up where I live) If you have a chance - BUY ONE, have fun and save at the pump! By no means is this a green vehicle, but its was able to pass air-care "a strict air quality regulation we have here" you used less gas then almost any car on the road at the time, and instead of sending it to the dump when most people would have, i instead rebuilt it myself with other parts from the dump. Sure this does perpetuate driving a car and consuming toxin emitting gas but... less so then most cars available on the market. How bout we call it greenish environmentally wise instead.
Technically this car even fits in the 3 R's of recycling
- Reduce - Engine mods I performed actually reduced the emissions that this car is rated to put out - as per the air-care exam proved
- Reuse - Rather then buying new parts, I used parts salvaged from the dump, both municipal and personal that would have been slated for recycling. Mind you, the heavy industries process behind recycling these parts is purely financial. Its cheaper for them to recycle the steel, but processing the used steel outputs more toxins then when originally forming it.
- Recycle - what couldn't be reused or mended was recycled properly. Even the broken safety glass found in quantity in the back seat when I bought the car was mixed into concrete by a local maker, makes for sparkly concrete counter tops!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
AWESOME!!!!
Having lived around the Rockies and Interior (Edmonton and Kelowna), I love hearing stories about little peppy cars like this having an easier time than most newer cars (and even some trucks!).
"I drove away and went for tacos"
Priceless.
And sounds very funny too !!
One question about the aluminium wing: how did you fix it? can you be sure that it won't fly away if you go past a certain speed?
Is it legal to have those customizations or you have to have them "checked and authorized by the police" (or something) ??
