Why should you care?
Aquaponics (AP) is easy and has been used for thousands of years (from Chinese rice paddys to the Aztec water gardens), can be practiced on any scale, consumes approximately 1% of the water in a traditional growing system, and is a great way to learn about closed-loop systems and ecology.
AP can help feed families in dire need of nutrition, with agricultural crops; but also with much needed proteins in the form of fish. This example isn't exactly what a poor family in a third-world country might put together, it is exactly as stated; an example.
The entire earth is (more or less) a giant aquaponic lab; but we're going to start small, in the living room.
Remove these ads by
Signing UpStep 1: What You Need
Tools needed:
Dremel
Scissors
Materials:
Rubbermaid Roughtote 18-gallon storage bin.
~18-gallons of water
~8-gallon "under bed" style tote.
~8-gallons of "pea gravel"
~4-ft of 1/2" tubing
2-liter bottle
End cap for tubing
Twine
~200-gallon/hr water pump with control valve (less is probably fine with a system this small)
On/Off timer with 15-minute intervals
Freshwater aquarium water tester (strips or kit)
Fish (I used 3 goldfish and a crayfish)
Seeds for planting (Fruiting or non-fruiting, lettuces, wheatgrass, it's all good)
Short stand or table that can hold ~80lbs or more.
If you had to buy everything for this as new, it would probably cost ~$30US including the fish and seeds but excluding the stand/table and test strips. As it is I had everything on hand except the pea gravel, so this cost me about $0.75 to make.
Options (not necessary for the purpose of this Instructable, but very valuable additions to AP in general):
Aquarium heater
Thermometer
Uninterruptable Power Supply (battery backup)
Grow lights, CFLs work fine (if growing away from sunlight)
Visit Our Store »
Go Pro Today »
I might also mention that we drop the water into the FT from the GB since it picks up oxygen when it is splashed in rather than pumping it directly into the water via a pipe and then trying to add air with airstones, etc. We drop it from one GB to another, picking up oxygen along the way. Our fish are not stressed, nor are they lacking oxygen.
This claims it can stock up to 1 pound per 1 1/2 gallons.
~Amish
