3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Organize cables with magnets
I was sick of the mess of cables to hook up cameras, external hard drives, phones and other paraphernalia to my computer. Luckily much of it has moved on to use the various sizes of USB, but some companies still use proprietary shapes.
I made use of the metal case on the computer to organize things a bit.
Step 1The only step...
The only step...
Of course there are not too many instructions to this.
Glue a neodymium magnet to a hard part of the cable. I used Gorilla Glue and it's standing up well so far. I glued mine to the PC side USB end on one side and the choke (the lump in the cable) on the other side. I like the magnet on the choke because I can grab the end of the cable and the magnet just pulls off and flops into place against the case, no fiddling.
If you  don't have enough USB plugs to keep the other end of the cable plugged in, and if you have a choice of cables lying around, use different colour cables so you can distinguish between them without having to follow them along to the computer.
8 comments
Jan 8, 2012. 9:41 AMweesuzi says:
the macbook has a powerful little magnet to dock the power cord jack to the female receiver.
The power transformer in your desktop pc is also magnetic
the HDD as stated also has magnets.
I would imagine the risk is very small, otherwise those smart fridges of the future are all sunk from day one. Not a happy thought now is it?
Aug 2, 2010. 12:20 PMhockeyandbeer says:
Aren't magnets harmful to HDs?
Dec 15, 2010. 9:38 AMdennis5587 says:
Magnets cause 'Flipped Bits' so while your data and hdd may be fine, this can definitely affect your transfer speeds and possibly corrupt data in the future.
The benefit to this may not be worth the risk.
Dec 16, 2010. 8:27 AMdennis5587 says:
As stated in my last response, a magnet has the ability to "flip a bit" meaning it can change a 1 to a 0 or a 0 to a 1. If this small magnet is flipping bits then you may experience one of the two side affects, slower transfer speeds or currupt data.
Since I am not entirely sure what checks are implemented in the transfer of data over USB, I can not say which possible side affect you may suffer. For example, when you transfer data over a wired network it is checked to make sure that what was transferred did not suffer any corruption during its travel. If it did then that packet must be re-sent. This can cause a noticeable change to the realized transfer speed. In some more extreme circumstances the currupt data can get so bad that data transfer is almost impossible.
If USB includes these checks then there may be a slow down in the transfer speeds. However if USB does not include these checks then that means the data being transferred is being stored currupted. This is a small magnet so there may not be many flipped bits, but given enough over a long enough period of time, it may come back to haunt you.
However like I said, I am not entirely sure of the USB protocols so I may be completely wrong :-)
Dec 17, 2010. 6:40 PMBaron Violent says:
USB uses CRC checks for two aspects: tokens (CRC-5, x^5 + x^2 + 1) and data (CRC-16, x^16 + x^15 + x^2 + 1). This is outlined at www.usb.org/developers/whitepapers/crcdes.pdf .
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:berserk
