Organizer From Old Container
514
6
6
Published
Introduction: Organizer From Old Container
Hi,
I was trying to reuse of old edible oil container and I found a link on Pinterest (https://in.pinterest.com/pin/56013589093086711/) showing making file organizer from a used milk cane. Here are the steps.
Hope it's useful.
Step 1: Mark the Container According to Desired Curve, With a Marker. I Used Sketch-pen.
Step 2: Do Marking on All the Sides Using a Measure Tap .
Step 3: Make 1st Cut. You Can Use a Paper Cutter.
Step 4: You Can Cut and Remove Both the Angular Portions, If You Want. Rinse and Wash It Clean. Now I Will Decorate This With Gift Wrappers or Colorful Papers.
Step 5: The Removed Handle Part Will Look Like This.
Step 6: One More Removed Portion Will Look Like This. You Can Still Reuse It to Make a Toy or Bird-feeder or Anything Your Creativity Suggest.
Step 7: A Bird-feeder Will Be Hanged From My 5th Floor Apartment With the Help of a String.
    • Spotless Contest
      Spotless Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    6 Comments
    Thanks for Pinterest!
    This would probably work well with the plastic jugs kitty litter comes in, as well. They're large and fairly sturdy, and to clean them out just requires a little rinse, since cat litter is just ground-up clay.
    yes, right.
