Introduction: Oriental Jewelry Box Made Using Cardboard & Wood.
I wanted to make a gift for my mother that would be unique so I chose to make her this. Basic materials using cardboard & a thin sheet of plywood 3/8th inch thick. Here's a list of what you will need.
Safety glasses, dremel rotary tool with various attachments, sandpaper, spray paint, clear coat spray, gel pens, elmer's clear dry glue, super glue, wood stain, clear coat spray, aluminum craft wire, small hinges, clasp, tiny screws, small lock, thin foam sheets, Jumbo craft sticks, wood burner, small sheet of 3/8" plywood, cardstock type cardboard.
Step 1: Making Wood Box, Woodburning, Stain, Color & Clear.
First I figured out the size I wanted the box & drew each side on my thin sheet of wood. I used dremel tool to cut them out very carefully to prevent splintering edges. Once I got the parts cut out I used super glue & C-clamps to hold the pieces in place until glue dried. I then sanded the corners to give the box a unique shape around where my scenes would be woodburned on. Next I added the small brass hinges & clasp. I then sketched the scenes using a pencil & woodburned them in permanently. I then stained the box & allowed it plenty of time to dry. Now I used gel pens of various colors to fill in the woodburned scenes giving them color. After giving the gel pen paint plenty of time to dry I added several light coats of clear coat spray.
Step 2: Making the Cardboard Internal Box & Adding Finishing Touches.
With the wooden external box complete now it was time to design the interior box. I carefully measured to get a box that would be just the right size to fill the wood box. I drew each side of the box onto the cardstock cardboard sheets & cut out & glued together. I used jumbo craft sticks for the drawers sides & made tiny loops for drawer handles out of aluminum craft wire. I did the same for the upper part which instead of a drawer it's a led that raises with a tokyo skyline scene at the back when I drew using gel pens. Before adding it though I spray painted the basic color & gave it time to dry & then masked off the edges & added the secondary color. I used gel pen to add the gold decorative lines & the tiger on lid & bamboo on the sides. I glued down thin foam sheet in top of box & added the tokyo skyline scene in the back. To finish it off I added several light coats of spray clear coat. I'm happy to say my mom really loves it.
Step 3:
Wood Contest 2016
Maker Olympics Contest 2016
Cardboard Contest 2016
