Origami Balloon
Published
Introduction: Origami Balloon
Origami Balloon
Step 1: Materials
- 1 piece of paper
- Scissors
- Pencil crayons/felt pens/crayons
Step 2: Colouring Your Paper
- Take your pencil crayons/felt pen/crayons and colour both sides of your piece of paper with whatever colour you want
Step 3: Getting Started
- Take your piece of paper and place it so it is vertical
Step 4: Making a Square
- Take the bottom right corner and fold it so it is almost to the top left corner (about 2 inches away)
- Cut the top piece of paper off, so that when you unfold the paper it makes a square
Step 5: Making a Smaller Square
- Fold your piece of paper in half so it makes a rectangle
- Turn your paper around so it is vertical, and then fold it in half so it makes a square
Step 6: Making a Triangle
 - Turn your piece of paper so that the openings are on the left side and bottom
 - Lift up the top flap so it is sticking up
 - Put your hand in the opening, take your other hand and push on the top of the flap
 - Then there should be a triangle looking shape
Step 7: Making More Triangles
- Take the right flap that looks like a upside down triangle and fold it up
- Do that same step to the left flap
Step 8: More Folding
 - Flip your paper around so the diamond shape is on the bottom, with the openings to the right
 - Take the bottom point and fold it up just to the line
 - Now flip your paper around so the diamond shape is at the top, with the opening on the left
Step 9: Finishing It Off
- Put your finger in your last little triangle shapes so they are more open
- Take your right little flap and fold it into the little triangle right above it
- Take your left little flap and fold it into the little triangle right above it
Step 10: Doing It to the Other Side
- Flip your paper over so that the shape you just made is under the top piece of paper
- The openings of the remaining flap of paper should be on the bottom and the right side
 - Lift up the flap so it is sticking up
 - Then there should be a triangle shape
Step 11: Finishing It Off
- Do the same steps from 6-8 on your remaining triangle looking shape
Step 12: Blowing Up Your Balloon
- Look at the two pointy ends, and there should be a little hole on one of the ends
- Put your mouth to the hole, and gently blow up your paper
- Then your should have a balloon
- DON’T worry if yours doesn’t look perfect, my first one didn’t look that great
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    • BBQ Showdown Challenge
