Origami Bamboo Sleeve and Yoke Dress
2,674
14
8
Published
Introduction: Origami Bamboo Sleeve and Yoke Dress
Hello everyone..... although i have been subscribing to instructables, I have never made one myself. When I saw this contest, I thought this is a good opportunity to start with.
I have tried to explain the best I could but this is a very confusing pattern and this instructable is preferable for those who have prior pattern drafting and sewing knowledge.
Step 1: Things You Will Need
  • Paper for drafting (any paper will do including newspaper)
  • Pencil
  • Ruler
  • masking tape
  • pins
  • scissors
  • fabrics - I have used 2 different fabrics which I had at hand. However, it is preferable to use a solid colored fabric to enhance the bamboo effect
  • basic extended bodice and sleeve pattern
Step 2: The Sleeve (pattern)
  • Take your basic sleeve pattern..... for this style to be enhanced , you need to have long sleeve (which I hate so I went with the shortest possible length with 6 bamboo slants)
  • Decide on the number of bamboo slants you need and number them from the hem line
Step 3:
  • Cut line 1 till the edge but not completely
  • Insert a triangular piece of paper +- 12 cm at the base
  • Stick with masking tape
  • Draw over the lines
  • Pin the triangle at the line and fold the pleat
  • Cut the excess at the hem and side seams
Step 4:
  • For bamboo slant no.2....... cut along the top edge of the first pleat until the line 2 intersection
  • Cut along line 2 till the edge
  • Follow same instructions as you did for line 1
Step 5:
  • Go along line by line working your way up towards center of sleeve
Step 6:
  • Finish all 6 lines .... at this point... I found that the pattern overlapped and I couldnt place it flat on the fabric so i added one more slit at the center and made another small pleat so that I could lay the pattern flat without overlap
Step 7: Sleeve (Cutting on Fabric)
  • Pin on fabric (you will need lots of pins)
  • Cut the pattern out on fabric
  • DO NOT stretch the fabric while moving it to the ironing board
  • Iron the pleats (you can do without ironing also)
Step 8: Sewing of the Sleeve
  • Sewing of the sleeve is done in the reverse order of drafting..... that is .... you start sewing from the top (the last pleat) and move downwards towards the hem
  • Details of sewing the individual pleat given with the yoke
Step 9: Yoke
  • I made 5 bamboo pleats for the yoke
  • The method is same as the sleeve
  • Cut each line, add triangular piece, fold and cut excess
Step 10: Yoke on Fabric
  • Pin the yoke pattern on fabric and cut
Step 11: Sewing of Yoke
  • Like the sleeve, we start sewing from the last line (the 5th one)
  • The first pleat (the fifth line) is not done like the bamboo pleat because it is too close to the neckline
  • Therefore I made it like a dart with the excess on the right side of fabric
  • Fold the 4th line,pin it (see the pic above)
  • Fold the fabric upwards and sew a thin seam to secure the pleat
Step 12:
  • Follow the same step for the next pleats until you finish all 5
  • Sew the right lower corner to secure the last pleat (the last pic)
Step 13: Bias Band
  • Take thin piece of fabric on the bias
  • Place a thick thread and sew the bias band
Step 14: Attach the Bias Band
  • Line the bias band on the edge of the yoke
  • Iron the yoke with bias band
Step 15: Bodice
  • Take extended bodice pattern
  • I have made zig zag hem
  • Cut on fabric
Step 16: Attach Yoke to Bodice
  • Pin the yoke on the bodice pattern
  • Sew top stitch on the sides
Step 17: Attach the Shoulders
  • Pin the shoulders
  • Sew the shoulders
  • Overlock the seams to give a neat finishing
Step 18: Neck Facing
  • Neck facing is cut for the front and back neck for the bodice
  • The shoulder part of the neck facing are joined together and the edges overlocked
  • Pin the neck facing to the main bodice right side to right side, pin the pieces
  • Sew around the neckline
  • Snip the seams so it is neater when you reverse it
  • Understitch the neckline, iron it
  • Hem the neckline
Step 19: Hem
  • I used the yoke fabric for the bottom part of bodice
  • Pin the zig zag and top stitch
  • I used the border pattern on the fabric at the hemline
  • Sew the side seams upto the zig zag only (as I wanted to make a side slit)
  • Fold and finish the side slits
Step 20: Final Piece
I thoroughly enjoyed making this project and hopefully you will too when you replicate this origami bamboo pattern.
Thank you for your patience :)
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    8 Comments
    Awesome Design
    Awesome work...
    Nice dress. All the best. ??.
    Excellent instruction. Very easy to follow
    Very nice
