3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Origami Cube Led Mood Lamp
This Instructable is on how to make a origami Cube Led Mood Lamp
The idea came to me when i first made an origami cube and thought it would be really cool if i lit it up with leds
You will need:
Lexan
Enameled wire
Clear wire tube
Leds
Screws
And lots of tools
Step 1Make lexan base
Make lexan base
  • last photo ←
This is the base at the top that the leds and cubes hook up to
it is made of 3 lexan pieces one has a cut out inside for the circuitry
I used a paint can for the outline then cut them out
for the center cut out use what ever is best you can find leave about 1/2" from the edge
I sanded the edges after with a belt sander
Drill holes for your screws you can use what ever you have or get some
Drill little holes in the bottom plate the same size as the clear tubing where ever you want them
and how many you want
2 comments
May 29, 2012. 4:21 PMMarik I. says:
This looks really cool. Can you tell me where you got that switch. I'm having trouble finding similar ones.
Sep 15, 2011. 10:16 AMmischka says:
look at my version of a color changing origami cube: http://youtu.be/2PBT5Bt5CZw ! cheers!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:ledfreak14
