Origami Garbage Truck - Remondis Model
Introduction: Origami Garbage Truck - Remondis Model
Here is the simple way to build one of the Central Coast's Remondis garbage truck model. This trucks is made out of card-board, and if you want to print a copy, click here:
You have a copy of this on a piece of card-board / paper. (BEST TO PRINT IN A3 SIZE OF PAPER)
Now, please follow the instructions... and you will have one of these magnificent replica's!
Step 1: Step 1. - Objects You Will Need
1. Scissors
2. Pin / Sticky Tape (To stick folded parts sticking out, to the correct model parts.)
Step 2: Step 2. - Getting Started
As you can see the picture with the truck on it (Not Set Up Yet), this is what it will look like on card-board or A3 paper. Firstly, you must trim the SOLID pink lines. Make sure that you have trimmed properly, as if it is not correct, it won't work out as an origami object.
Step 3: Step 3. - Folding
Fold the dotted lines the correct way, so that the connection side's match.
Step 4: Step 4. - Using Sticky Tape or Pins.
If you want, you can use pins for making this origami object, just follow the instructions on this screen-shot picture of the truck. Or, if you don't want to use pins, just go with sticky tape, as it will make the building of the truck easy. Use sticky tape on the parts where they are meant to connect.
Step 5: Step 5. - Finishing Up
Make sure the tape/pins are in the right position, so the truck is alright. Make sure that if there are any bits sticking out of the card-board, just trim them, so they won't stick out.
Step 6: Step 6 - Finish
Then, presto! You have your origami truck... as you can see, I made myself two, and put them on top of my AC. :D Hope You Enjoyed This Origami Object
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Here's the complete link.
    its not origami, its a papercraft/model
