Origami Popuot Valentines Kiss Me Card
695
9
Published
Introduction: Origami Popuot Valentines Kiss Me Card
What You Will Need
1: 2 Sheets Of Paper Any Colour And A White square 15cm x15cm
2: A Ruler
3: Scissors
4: Glue
Step 1: Cut and Fold
Make A square
Measure Along The Base 4" or 10cm
Fold At 10cm On Both Sides
You Will Need The Last Photo For This Step
Step 2: Fold Some More
You Will Have Two Corners Overlapping Each Other
Fold The Corner Up In Half Then Down In Half, Making New Folds Each Fold
Fold The ~ Corner Up Along The _------
__________
\ _------ /This Edge Wants To Be Along The Top Line
\ /This Edge Wants To Be Along The Top Line
\ / This Edge Wants To Be Along The Top Line
Here Up ~
You Will Have A Pyramid Hanging Off The Edge, With The Long Side On The Bottom Fold Vertically In Half, So The Right Side Lays On The Left
Repeat On The Other Side
Then Unfold All The Way
Step 3: More Folding
Fold One Third In (Two Lines In)
Fold The Other Corner (One Third) On Top
Fold The Littel Corner Up (As Seen In Third Photo)
Step 4: Keep Folding
I
I
As Seen Above Mountain Fold Where The/ \ Are (That's About Life Size)
DO NOT PUSH THE POINT DOWN
And Repeat On The Other Side
Pinch Below The Middle Of The Point On Both Sides And Push In
Step 5: It Should Look Like This
Both Tips Should Be Even, Mine Are A Bit Offset
Peel Both Front And Back From The Middel
Fold The Tips Down
Pull Out And You Have The Lips
Step 6: Now the Card
Cut The Second Piece Of paper 30cm x15cm
Fold It In Half And Unfold
Fold The Four Corners In
Then Fold The Two Points To Touch Each Other
Put The White Square in (As Shown In Photos)
Fold In Half
Step 7: Glueing Together
Put Glue On The Card (As Shown)
Get The Lips And Line Them Up With The Fold Line (Not The Front)
Squash The Lips And Close The Card
Befor The Glue Dries Open It Up And Put One Drop Of Glue On It
You Will Have Two Pockets To Put Your Cards In (Last Photo)
Glue A Tag On The Back Of Your Cards So You Can Pull Them Out
To Stop It From Being Pushed Opened Put A Drop Of Glue On Two Corners
Your Done Have Fun!!
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    • BBQ Showdown Challenge
