3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Original XBOX Hard Drive Upgrade
This instructable details the installation of a larger hard drive into a soft-modded original XBox.
Here I recount my experience upgrading the original factory hard drive of the XBox to a Seagate Caviar Blue 500 GB Desktop (3.5") drive (WD5000AAKB).
Step 1Parts / Tools
Parts / Tools
For this instructable the following parts and tools are required:
- A Torx screwdriver
- A Molex hard drive power cable "Y" splitter
- A new hard drive for installation
- A modded XBox
- Chimp XBox Hard Drive cloning software (available at "usual places")
A list of compatible hard drives can be found at the Xbox Hard Drive Compatibility Chart.
Details on soft-modding the Xbox can be found in my previous instructable, Original XBOX Softmodding.
16 comments
Sep 10, 2011. 12:49 PMdfalk says:
Does its support 500gb??
Nov 21, 2011. 12:08 PMjgosselin says:
the fact he completed the instructable and says its working with his partition layout. your answer is yes.
Apr 20, 2012. 7:32 AMThe Dark Lord says:
Can it be done without partitioning?
Apr 3, 2012. 10:17 PMwolfemanpa says:
There are a couple things that need to be pointed out that are not in this tutorial and others I have seen. After a softmod is performed, there is not automatically an Apps folder created, in fact, one would be led to believe that a directory named APPLICATIONS, would be there given the evox dashboard listing, along with an EMULATORS, GAMES, et al.
You must install the chimp folder via ftp into a directory named "Apps". and the linux config file inside the chimp folder into the root of the E directory. Otherwise you will get errors when booting chimp and trying to start the app.
The other point is, well more of a question really, how do you merge the resulting partitions? I can not install my games or emulators, as far as I can tell, on any other partition than the E partition... so how do you make use of all that extra space if after the clone, you are left with a 4GB sized E partition?
Feb 15, 2012. 8:28 AMJon316 says:
This is really easy to do all you have to do is connect hdd to computer and use xboxhdm. I did though explore some tuttorials first just to get comfortable with xboxhdm.
Feb 9, 2012. 7:36 AMricardo10452 says:
While my HDD is cloning, the screen goes black. How will I know when the cloning is done? Is there an on screen message? When I hit the button on the controller it goes straight to the menu screen. Does this mean its done or did I interrupt the process? Any information will be highly appreciated. Thanks! =)
Aug 18, 2011. 12:34 PMMichaeLeon88 says:
Trial and error is a little scary. I had to plug the jumper back into the hard drive to restore it to master for the dashboard to fully load.
Otherwise I was given the xbox needs service screen.
Aug 18, 2011. 12:00 PMMichaeLeon88 says:
I wish it was as easy as clone master to slave. You have to select a few settings before it does. I was kinda lost but I just said yes to everything.
Mar 11, 2011. 10:04 AMbjk311 says:
Can i use the same HDD listed above for my xbox or does it have to be specific version?
If so, how can i find out which version xbox i have?
thanks for the help
Jul 6, 2011. 1:51 AMzack247 says:
any IDE hard drive should work, so long as its properly formatted.
Apr 30, 2011. 1:36 PMTreborabc says:
You can do this much more easily with xboxhdm and a ftp client
Apr 8, 2011. 10:11 PMSnaffle J. Bean says:
Will this keep my softmod, or will I need to re-softmod my Xbox after I put a new hard drive in?
Apr 9, 2011. 11:01 AMSnaffle J. Bean says:
Okay. One last question: I'm going to be using an old hard drive with data on it from a previous computer. Will I have to format this hard drive, or will Chimp do it?
Jan 29, 2011. 5:40 AMSirppi says:
Thanks a lot (: i finally managed to change the HDD using this tut (:
Oct 17, 2010. 3:18 PMjunits15 says:
I believe its an IDE cable :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:myles_h
